I have a computer that will not boot up...bios sum check do i flash the bios without the computer running windos
  • 367 Answers
Look at the mother board depending on model etc there may be a jumper (small piece of plastic with metal contacts inside) This being moved to the proper pins will help you clear the bios to factory.
Posted on Jan 05, 2009
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Boot block compatible version ver 0.16 bad bios check sum.bios recovery floppy not find. cd rom not find. i want a solution for this . iam using asus p5rd1-vm motherbord pls help me frnds
Your bios i corrupt. You will need to download bios for your mother board, burn it on a cd and flash your motherboard bios. Go to your manufacturer site for more information on how to flash your bios using CD.
Nov 27, 2012 | Computers & Internet
My sistam is not restore ... WHY???
This error code usually points to an installation of windows that has been corrupted. I'm assuming that you have no USB flash drives plugged into the laptop when booting, if so, remove these and try a reboot.
Then try to boot to safe mode (f8)
If this fails, boot from the CD drive by setting the DC boot option as 1st boot in the bios, put the windows installtion CD in the drive and go through the install proceedure, selecting the REPAIR option.
If this fails, you will need to reinstall windows.
To recover any lost files, after reinstalling windows, download a utility such as recover my files and set it to a format recovery to get any lost files back.
Jun 21, 2012 | Samsung R530 22GHz Intel Core Duo...
Drive A media error bios checksum error
your current bios is corrupted since the check-sum that was generated when your bios eprom was flashed with your current bios version doesn't match the check-sum that is generated as now, meaning that your bios changed for a few bits. you can fix this problem by re-flashing your bios with a good ROM file that you can download from your computer maker site or your motherboard bios maker site, also upgrading your bios with a newer version will take care of the issue as well.
Mar 07, 2011 | Computers & Internet
I have toshiba tablet without a cd-rom and want to farmat the system and it is useing xp windos os but even when i using an external cd-rom it load the os what do i do?
Before the computer boots press Del key constantly then the Bios screen appears in that change the first boot device priority to CD Rom then exit the Bios by saving the changes. This should help you in recognizing your OS disk...
Sep 15, 2010 | Toshiba Computers & Internet
if you can enter bios (usually by pressing f2 or del), then load the default settings, otherwise, you will have to position the jumper properly, instructions for that are as follows.
1. Touch an exposed metal part of the case to ground yourself.
2. Unplug the power supply from the wall.
3. Move CMOS reset pins to short pins 2 and 3, then wait 10 minutes.
4. Replace CMOS reset pins back to 1 and 2.
5. Replug the power supply and boot.
Jan 20, 2009 | Acer Aspire™ T180 PC Desktop
Bios check sum error
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
This messages indicates that the BIOS could not be located and loaded up. Normally this happens when the BIOS is corrupted. The corrective action required is to re-flash the BIOS using a DOS bootable diskette in the 1.44 FDD. Aside from the BIOS file, a flashing software is also needed. Pls start here.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | MSI K9VGM-V Motherboard
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
