Question about Toshiba Satellite C655-s5090
How to install built in camera in satellite c655
  • na
    na Nov 08, 2012
     from you question its hard to work out what your actuall question is.maybe take a little more time to define it
  • Toshiba Master
  • 7,627 Answers
If you have a webcam it will be configured in the Device Manager> open Imaging devices if you have one it Should be listed there. If it is enabled and working properly then you are good to go. With the information you supplied that's the best solution I can give. I you will supply us with the Make, Model, and OS we could give you a more informed solution
Posted on Nov 09, 2012
4 Suggested Answers
  • 93 Answers
SOURCE: hi! i got a toshiba
Reinstall you drivers, for more informations download EVEREST and post problem here.
Good luck, Jopica123
Posted on May 17, 2011
howard_compu
  • 211 Answers
SOURCE: How to upgrade/install RAM in Toshiba Satellite
A small cover will be located under your machine that needs a small phillips bit screwdriver to open. Once the cover is removed the chips can be pulled out by pressing outward the two clips retaining the chips - the chip will pop up. Reverse the process to put the chip back being carefull not to touch the shiney connections.
Posted on Sep 12, 2011
  • 4961 Answers
SOURCE: why no power in my toshiba laptop C655-S5140
You might need to replace your power cord/charger.
Posted on Jun 30, 2012
Toshiba satellite c655 doest it have internal microphone
Built in mic issues Satellite C655
Check the bottom post.
to get to device manager, click start > right click 'computer' > properties > device manager (top left) go to sound on the list
uninstall the sound driver by right clicking it
restart the computer
Jun 11, 2014 | HP Pavilion dv1000 Notebook
Toshiba satellite c655-s5549 wireless
Hi
Go to this website and provide laptop model number and download & install drivers for your Wireless NIC
https://www.toshiba.eu/innovation/download_drivers_bios.jsp
Feb 16, 2014 | Toshiba Satellite 15.6" C655-S5549...
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
Jan 30, 2013 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-S5125 -
The Toshiba Satellite has a helpful program -- the Toshiba Wireless Manager -- to eliminate some of that frustration. Connecting to a wireless network using the built-in wireless usb wifi adapter on a Toshiba Satellite may require making some initial changes to the Satellite's settings. These changes can be made using the Toshiba Wireless Manager. As with all wireless networking, the settings of the laptop must match the settings of the network.
Mar 12, 2012 | Toshiba Satellite C655-S5125
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Do toshiba satellites c655 have a built in mic?
The Toshiba Satellite C655 does not have a built in microphone, but it does have a mono microphone jack.
The following website has microphones that are compatible with the microphone jack. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007675%20600011221&IsNodeId=1&name=3.5mm
You may verify at Toshiba's C655 website. It says "No Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite/C650/C655-S5049
Compared with the L670. It says "Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite-pro/L670/L670-EZ1710
I hope this answers your question.
Sincerely, Nathan Hicks
Mar 01, 2011 | Toshiba (P000257700) Microphone
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
Feb 16, 2011 | Toshiba (P000257700) Microphone
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-s5090 Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
