Question about Lexmark T642 Laser Printer
PAPER JAM OCCURED CONSTANTLY IN MY LEXMARK T642 PRINTER
  • 29 Answers
SOURCE: Lexmark P6250 paper Jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 05, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark X4850 paper jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 13, 2008
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
  • 684 Answers
SOURCE: Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Posted on Apr 29, 2009
SOURCE: paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Posted on Aug 22, 2009
200.12 paper jam
The 200 and 200.xx Paper Jam error messages indicate a problem with paper jammed at the front of the printer, under the toner cartridge. To resolve this issue, please refer to this article: http://bit.ly/122frro.
Dec 05, 2012 | Lexmark T642 Laser Printer
I can not print from my lexmark t642 printer. I get this message " Remove paper from Standard paper bin." I do not have any paper in that area.
If there is no paper on paper bin and you are getting error to remove paper from the standard paper bin, please check for paper jam. it possible that paper stuck right on the path on the paper bin.
For further assistance, please contact Lexmark Technical Support.
Sep 12, 2011 | Lexmark T642 Laser Printer
How do I clean the heads on a Lexmark T642 as it is starting to leave large ink drops on the paper
A T642 has no "heads"as in an inkjet. "Drops" on the paper are mostly caused by a leaking cartridge. So try replacing the cartridge.
Oct 06, 2010 | Lexmark T642 Laser Printer
Is there a way to take off the back of the printer where the paper comes out. Paper is jammed in the rollers and can't get to it.
Here's an article on A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark T640, T642, or T644 Printer. This might help you remove the paper jam in your printer. Just click on this link: http://bit.ly/9LXkka. Hope this helps.
Jul 03, 2010 | Lexmark T640 Laser Printer
200.13 paper jam
that is referring to a jam under the toner cartridge..are you using genuine lexmark toners??
Jan 07, 2010 | Lexmark T642 Laser Printer
The T642 jams constantly under the toner cartridge when printing from the manual tray.
Hi, Make sure you have all of your paper settings properly configured in the Paper Menu of the printer. Paper size, type and weight. Then make sure there is nothing blocking the path of the paper as it enters the printer. That will be easy to notice since if there was and obstruction the paper will get damaged. If there is nothing in the paper path then the printer must be giving you an error. If its a 201 then the input sensor(little plastic flag under the toner) could be damaged. If it gives you a 202 then maybe the fuser exit sensor is damaged. In that case you will have to contact Lexmark's tech support so that you can get help if your printer is still under warranty.
Dec 14, 2009 | Lexmark T642 Laser Printer
On a T642 prints out first three sheets just fine but on 4th it never makes it to the fuser. The paper curels inbetween the fusers and toner. 201.32 error
The error 201 means exactly what you are getting;
a paper jam between the printer input and exit sensors.
It is common on these printers for toner to build up on the fuser input guide and eventually gets so big as to catch on the leading edge of the paper,
you will need to scrape the encrusted toner off of the guide.
If the device has done a large volume of printing (say over 100k) it may be a faulty fuser assembly.
Oct 05, 2009 | Lexmark T642 Laser Printer
Lexmark T642 display says paper jam check rear door. There is nothing jammed! What can I do
The sensor in the fuser unit is jammed/broken. The fuser will need to be repaired or replaced.
Aug 13, 2009 | Lexmark T642 Laser Printer
Im getting plain paper jam at the fuser... I work for a large Hospital , and at this locations we have about about 100 pirnters they all are lexmark T642 and 50% of them have 3 to 4 tray and labels and...
You can replace those rollers. They wear smooth very quickly. In a pinch you can also peel them off the hub and put them on inside out. It will give it traction. It sounds like you already know about the little sensor in the trays themselves. I've seen them pop out of position and cause those probs. I don't think they could have made those sensors any cheaper if they had tried!
Apr 08, 2009 | Lexmark T642 Laser Printer
T642 Paper Jam and Check paper stock jamming.
You need to change the paper type when using card stock, plain etc.
As for the paper jams; you need to check the exit sensor at the exit door, also if you have a duplex, 2-3 drawer you also need to check for jams.
Sep 08, 2008 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
