Question about Canon imageRUNNER 5570 Copier
Canon ir 5570 e0121-0001
La maquina a la ora de q inicie a alistar tira el eror en la pantalla
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
ginko
  • 19396 Answers
SOURCE: como instalar la cannon ip1500 sin el cd instalador
Tiene que descargar las controladoras aqui: iP1500
Posted on Oct 26, 2008
  • 92 Answers
SOURCE: en la copiadora aparece la clave de error EOOO y no la se quitar
tens um problema com a unidade fusora chama um tecnico da canon
Posted on Dec 22, 2008
  • 118 Answers
SOURCE: Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Posted on Jul 16, 2009
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Como resetar drum da Okidata MB480
Trate esto:
REPONGA de OKIDATA TONER BATERIA.
Encienda maquina al empujar y teniendo los DOS botones de men? de arriba/abajo en mismo tiempo.
2. La ventana del menu mostrara "OKI USUARIO"
3. Desplace a "el Modo de Dialogo de Motor" es indicado. El empujon Entra boton.
4. "Xx diagn?stico de Modo. xx. el S-MODO de xx es indicado.
5. Desplace al inicial de NV-RAM es indicado. El empujon ENTRA.
6. La ventana muestra "NV-RAM- Inicial Pospone 1".
7. Empuje EN LINEA y ENTRE Botones simultaneamente y el ASIDERO por 10 segundos despues usted ve "Ejecutar
Repuso" parece en la ventana de menu.
8. Reinicie impresora.
Todo el toner, la bateria, las figuras de fuser y transferencia vuelven a 100%.
Permita que sepa si esto ayuda.
Jul 19, 2011 | Oki Electric Industry Okidata MB 480 ...
Como actualizao firmware de toshiba estudio 350
Con la maquina apagada y el USB connectado, oprimes 49, prende la maquina hasta que se oyes un tono, despues de eso se ve el firmware en la pantalla. Oprimes start y comenza el firmware update. Espero que te ayuda.
Jul 14, 2011 | Office Equipment & Supplies
Quiero vender mi registradora casio PCR-T2000A, necesito resetearla a "0" como lo hago?
La forma mas rapida para restablecer esa maquina es quitar el enchufe de la pared y saquar las baterias, dejalo alli durante cinco minutos, reemplaza las baterias primero, seguido por el enchufe en la pared.
Al girar la llave a Reg prenda la maquina. Una fila de ceros aparecean en la pantalla. Ahora puedes configurar la maquina desde el principio, incluyendo hora, y fecha codigos de impuestos.
Jul 08, 2011 | Casio Parts Cash Register PC Desktop
AYUDA! hablemos ingles no quiere funcionar porque me dice que no puede inicializar el servidor del habla. que puedo hacer?
He encontrado la solución.
1-Instalar Hablemos Inglés en el Vista.
Hay que instalar una máquina virtual (Virtual Box por ejemplo), con el Windows XP, y crear una carpeta compartida (la que tenga Hablemos Inglés instalado en el Vista). Se ejecuta el programa desde XP, y se graba una palabra para que inicie el servidor de habla.
2-Se pasa al Vista sin cerrar Hablemos Inglés en el XP.
3-Ejecutamos Hablemos Inglés desde Vista, y empieza a funcionar.
4-Ya podemos cerrar la maquina virtual con el XP.
Es un poco complicado, pero funciona.
Ojo, si utilizas Hablemos Inglés desde el XP virtual, probablemente el sonido de las grabaciones no sea bueno, por lo que hay que utilizar la versión que corre en Vista.
Todo esto es para hacer que se inicie el servidor de habla, y vista pueda ejecutarlo.
Saludos y suerte.
R@in.
Apr 26, 2011 | The Learning Company HABLEMOS INGLES - VER...
Al encender la maquina aparece la leyenda de que "windows no se ha iniciado correctamente " y al seleccionar alguna opcion modo seguro , modo seguro con red , se apaga la maquina y vuelve ...
repare instalaci?n:
1. Cuando la Prensa cualquier llave inicialice del mensaje de CD es demostrado en su pantalla, aprieta una llave para comenzar su ordenador del Windows XP CD.
2. Prensa ENTRA cuando ve el mensaje Al arreglo Windows XP ahora, y entonces prensa ENTRA demostrado en el bienvenido a pantalla de Arreglo.
3. No escoja la opci?n para apretar R para utilizar la Consola de Recuperaci?n.
4. En el Windows XP que Licencia Acuerdo, prensa F8 para aceptar el acuerdo de la licencia.
5. As?gurese de que su instalaci?n actual de Windows XP es seleccionada en la caja, y entonces aprieta R para reparar Windows XP.
6. Siga las instrucciones en la pantalla para completar Arreglo.
Feb 20, 2011 | Computers & Internet
Tengo problema con impresora mfc210c en la pantalla dice eror36
El error 36 es cuando el Purge unit de la maquina esta lleno, hablando claro es una esponga que recoje el residuo de tinta y es contabilizado por la maquina, ella asume que ya esta lleno y nesecitas remplazarlo.... en este caso nesecitas visitar un dealer brother o taller.... www.brother.com para mas inf. sobre un dealer autorizado...
Oct 03, 2009 | Brother MFC 210C All-In-One InkJet Printer
Call for service CD4 en estudio 650
CD4 indicates full toner bag, need to be disposed...
Mar 25, 2008 | Toshiba E-STUDIO 650 Copier
Canon imageRUNNER 5570 Copier Logo
173 people viewed this question
old marine
old marine
