How can I find my IP Address for My Arris TG862G/CT modem
davidtcpc
  • 10 Answers
SOURCE: I need to find my
Try typing 192.168.0.1 in your Internet browser. If you have access to the modem, this will give you your Settings page which you can use to update the password.
If you cannot access that page, press and hold the small reset button on the back of the modem with a small pen or paper clip for 60 seconds. This should return the modem to factory settings, and allow you to reset the password.
Posted on Aug 23, 2010
SOURCE: failure to acquire IP address
How is the DHCP setting of the modem configured?
Posted on Nov 05, 2007
  • 27 Answers
SOURCE: change modem
First, I would try resetting the modem by unplugging for 10 seconds or so and then plugging it back in. To be on the safe side, I would also reboot computer. AFter that, I would try to see if it picks up valid ip address. If it doesn't, you may need to call your cable internet provider and perhaps get the mac address of your modem in their system (if it's not already)
Dman
Posted on Dec 29, 2008
  • 54 Answers
SOURCE: i can't find the IP Address on my ARRIS Router!
the ip address should be given automatically by the router but since it is asking,
in your computer go to start,run,type in cmd and hit enterm
it should open a black box in that box type in ipconfig and hit enter,
it should give u a list of result,search the one which says ip address,
if the ip address of ur computer is 192.168.1.2,then the ip address for your xbox should be 192.168.1.7,
if the ip address is different than the example i gave you just make sure that the difference between the last numbers should be 5 atleast....let me kno the ip address of your computer and i can tell what ip address u need
for the xbox...........
Posted on Feb 05, 2009
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Posted on Apr 09, 2009
How to configure it
Disconnect the coaxial cable from the Arris.
Turn the Arris off.
Connect an Ethernet cable from your computer to the Arris.
Turn the Arris on.
Turn on (or reboot) your computer.
Open a command-line prompt on your computer.
Enter 'IPCONFIG' to see the IP-address of the "default gateway".
Open your web-browser, and type that IP-address into your web-browser, to access the configuration-page of the Arris.
Configure the Arris.
Turn the Arris off.
Connect the coaxial cable.
Turn the Arris on.
Reboot your computer.
Done.
Jun 04, 2015 | Arris New Sbg6580 Surfboard Extreme 3.0...
How do I make my gateway wireless tg862g surcure
Thanks for posting on Fixya!
If you are comfortable working with networking devices, there is a users manual at the following link;
http://setuprouter.com/router/arris/tg862g-ct/manuals.htm
Page 17 has a pic of the rear panel layout. It will show you the reset button, and you can use a toothpick to gently push in the button and start fresh with factory. It will reconfigure itself using providers data that it will download and setup. YOU can then start fresh with it. YOu can also contact your cable provider, for more help with this issue. (I know, THAT stinks!).
Don't forget to rate this answer if it helped you!
Apr 09, 2014 | Gateway Wireless-B Router (wbr-100)
Invalid user name or password
Have you made an attempt to enter the controller using the 192.168.0.1 in the command line of your internet explorer? The numeric sequence may need to changed using 192.168.1.0 or other codes as I cannot advise which address is available to you. Once you are in the setup using adm and No password, everything else is up to you.
Mar 12, 2014 | Computers & Internet
I have an arris tm602g. What is the IP address to access modem 192.????
Try 192.168.0.1 or 192.168.100.1. Make sure that your pc is connected directly to the Arris TM602G modem and not on a router.
Aug 28, 2011 | Arris Computers & Internet
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
What is the web site for arris so i can find the defalt ip address
hi
the default IP Address for Arris is 192.168.2.1
user name :N/A or admin
password :Blank or admin
click here learn more /port-forwarding
(please Rate Me)
Dec 30, 2009 | Arris Touchstone 450a (CM450) Modem
I have a Arris Modem and can not get on to the internet. The IT people at Bresnan took a look and found nothing wrong with the Arris. The modem is able to ping and says its online and ready to work, but...
Do you have a cable connection kyle? i think you're using a vista operating system. Click on START, in start search bar type CMD then you'll see the command prompt as a search result. Right click and run as administrator. When you have command prompt, try to ping any website, for example www.yahoo.com. if you're able to ping yahoo that means your connected. If not do IPCONFIG, check your IP address and call your ISP, ask them if its a valid IP that they're giving out.
Aug 29, 2009 | Arris Touchstone 450a (CM450) Modem
Need solution to Networking 2 comps thru an Arris tm602g/ct via a linksys 8 port switch, the seems to be no Usb connection on the modem
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
Mar 18, 2009 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
2,367 people viewed this question
David Payne
David Payne
