Question about Kenmore Elite 45986 Front Load Washer
I have a knemore elite HE5T and keep getting the code F20?
  • Anonymous Jan 06, 2009
    The washer begins cycle, stops at 11 minutes left, DF blnks, F blinks, et.
  • 5,911 Answers
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 06, 2009
My Kenmore Elite HE 5t is showing the F20 code 15-20 seconds into the washing cycle. F20 standing for Water inlet problem. We have cleaned and checked all inlet ports and they are good so what else
Hello Shannon;
My name is Peter. I am a retired field service appliance technician.
Code F20 also stands for pressure switch.
You have a incomplete model number so I am not sure if this is the correct switch.
Substitution: W10514214 - $48.00
This is just inside the top cover, right hand corner.
The diagram is on the following link. Plug in your model number.
Water Filters Lawn Garden Appliance Parts
Dec 11, 2014 | Kenmore Elite HE5t Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
Recently I have been getting an F20 error message. What does this mean?
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
I've seen this complaint 5-6 times within the last month. Try this. Remove the top panel by removing the three screws along the back and pushing the panel back and then lifting up. Locate the pressure sensor mounted on the right side of the machine. Check the pressure sensor hose very carefully for splits or cracks caused by chafing on the tub. You really need to look closely, it only takes a tiny pin hole. If damaged, replace hose and make sure the new hose is routed properly, not taped to the tub as some of the new ones have been for some reason.
Mar 26, 2010 | Kenmore Elite 45986 Front Load Washer
F20 message on washer kenmore elite HE5t
Feb 28, 2010 | Kenmore Elite HE5t Washer
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
I am repeatedly getting an F20 error on my Kenmore HE5t washer. It seams the the spin cylce before the final rinse is the sticking point. I have to unplug, restart and finish the cycle with final rinsie...
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
Oct 12, 2009 | Kenmore Elite HE5t Washer
Have kenmore elite HE5t giving code F20 help pls
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
369 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
