Mitsubishi Mirage Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
SOURCE: blinkers dont work on my
Turn signals are operated by a different fuse then the hazard flasher - start by checking the fuses - if they are okay you may have a seperate flasher unit for the turn signals too - you may need to replace the flasher unit - hope this helps - good luck :O)
SOURCE: I am trying to install
Constant 12V+
Red/Black
Switched 12V+
Blue
Ground
Chassis
Illumination
Green/White
Dimmer
Black/Yellow
Antenna
Driver's Pillar
Front Speakers
4" Dash
Left Front (+)
White/Blue
Left Front (-)
Black/Blue
Right Front (+)
White/Red
Right Front (-)
Black/Red
Rear Speakers
6" x 9" Rear Deck
Left Rear (+)
Yellow/Blue
Left Rear (-)
Gray/Blue
Right Rear (+)
Yellow/Red
Right Rear (-)
Gray/Red
I'm trying to install a new tuner and i don't know what the colours that are in the car mean for the positive and negative for each speaker
