Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
When hot water is on & toilet flushed the temp drops
This just started last month, before you could have the shower & a faucet going & flush the toilet and the temp would not dip.
  • Doug James
    Doug James Jan 06, 2009
    The pressure does not drop the temp does. It is like the heater just stopped working but once the toilet stops or other faucet it turned off the temp comes back up. the unit is about two years old.
    I have a filter on the supply from the street & a pump to keep the pressure up you can have about 4 things going before the pressure starts to drop.
    Scholar:
  • 50 Answers
Check strainers and screens into the sink, at the spout and into the hot water heater. Sediment buildup could be limiting the flow which woul make the system more susceptible to pressure drop when the toilet is flushed.
Posted on Jan 05, 2009
  • Tripp REa Feb 10, 2009
    Its not the temp from the water heater. Its an imbalance between the hot and cold pressure going through the shower valve which is resulting in more cold than hot getting through the valve. No way is the water temp from the heater arbitrarily dropping in correlation with the toilet flush.
We have a problem with our Rinnai 24 hot water service. Hot water goes hot and cold. Does not keep to 38 degrees temperature when showering.
Do You know if there is an anti scald valve in the shower valve? If so it may be scald up with corrosion and need replaced! To see if this could be the problem, flush the toilet next to the shower while the shower is running. If temperature changes in shower I would say that is your problem! If You need to replace it, it would be cheaper to do it yourself! They should be videos on Youtube on how to do it! Good Luck! Regards!
Jul 14, 2017 | Rinnai Water Heaters
Reduced Hot Water
Water heater 14 years old, probably has never been flushed, Flush recommended at least every 6 months, Build up inside tank may be to late to flush, but you can try or replace heater.
press the helpful button
Feb 11, 2016 | Element Water Heaters
I have a Richmond RCN 0595A12328, MODEL 5V40-7 40 gallon water heater. Can you tell me if there is some kind of an assy. I can use on it so when a toilet if flushed someone in the shower does not get...
The water heater has nothing to do with it. You need a shower control valve that won't let the water pressure change when the toilet is flushed. Moen makes just such a valve called a pressure balancing valve. Moen L82683 Positemp Tub/Shower Valve. http://www.moen.com
Jan 07, 2015 | Water Water Heaters
Powerstar ae125 runs hot then cold in shower
Increase your flow, sounds like you are right at your activation rate.
1 way is to turn down the temp on the machine, so you dont have to mix in so much cold at your shower. Check to see if your mixing valve is bad, or your showerhead has restriction/scale built up in it.The other way is to turn on your lavatory fixture full hot before showering(which will keep hot water flowing through the machine as you adjust your temp to be comfortable.
Nov 24, 2013 | Bosch PowerStar AE115 Tankless Water...
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Water does not stay hot it is uneven in shower, from cold to hot then hot to cold
Ok that sounds more life a faucet that is bad. In today world, the newer (20 years and less) they have pressure balance faucets. Have the faucet serviced. NOW lets look at an other area check out your home to see if you have a cross connection. A cross connetion is a place where hot and clod water meet. I know that everywhere but the toilet!
Yes thats true. But we buy all kinds of things that we attach to a fauects or tub spouts. Lets say you attached a hose to the sink in the garage to wash the dog with warm water. if you turned the water off at the handle of the hose and you left the water on at the faucet. BINGO
the hot and cold water mix and then up and down water temp while taking a shower.
So start looking first before spending any money. if ANYTHING is attached to any faucet take it OFF and then take a shower.
Be safe
Thanks
Tom ( how did we do ?) :)
Sep 11, 2011 | Bosch Water Heaters
I have a noritz 069 M and what has been happening For the last few months is that while taking a shower the hot water will get super hot then shut off. The only way for it to come back on is to turn...
well it is time to get the the two way valves to both side, I would use only a product the noritz says to use.
Now if you cant get it you can get other products that break up lime and scale from you local store that sells plumbing product. I you can see I dont list a store or a product I am here to help you repair your heater, Not have you buy from one store or an other.
With that being said you can vinegar but dont use acid. If yuo "burn" the inside of the heat exhanger you jusy might be buying a new unit. also Please flush out the system with cold water for at least 10 mins. with the 3 way valves that should be very easy to do.
You also might have a lime build uo in the faucet also which will affect how they work. You may want to replaced and cleanout the cartridge and see if you have a lime build up. If that is the case you might want to think about a low priced water filter or softener.
Hope this helps you out and please dont for get to rate me, and Be safe
Tom
Sep 10, 2011 | Noritz 6.9 Gallon Residential Direct Vent...
Our water heater runs out of hot water after a couple showers. Does it need to be replaced? Is there something on it that I can check? Does increasing the temperature setting help?
when was the last time that you have "opened the flush valve (faucet) at the bottom of the tank to clear out the sediment? if it has been more then 4 years then you will need to do this depending where you are located this should be done once a year just to keep the tank clean. attach your garden hose to the valve and run it over to the sink open the valve for a few moments to clear out the tanks bottom (HOT WATER ALERT!) after doing this and if you have seen dirt come out then your tank should be clear. check to see what the tempature is every 1/4 inch is 10-30* increase hope this helps
Jan 20, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Shower gets hotter or colder when toilet is flushed.
This is typical for an installation without a balanced valve/anti-scald valve on the shower.
If you are using manual on/off valves on the shower, about the only way to fix this is to install the device mentioned in the previous paragraph.
May 03, 2009 | Rheem Tankless Hot Water Heater...
Only hot water in sink/basin when toilet is flushed
I had a customer a few weeks ago that had the same problem. When the water heater was installed they crossed the supply lines. They had the inlet as the outlet. Esentially, the water heater was plumbed in backwards. Also there could be a miss piping somewhere in the house but it would probably be near impossible to find it right now without tearing up foundations. Also check that the faucet is not plumbed backwards as well. Especially if this is a single handle faucet that you are referring to.
Apr 06, 2009 | Rheem Tankless Hot Water Heater...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
245 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
