Question about Paragon 7007-00 Electromechanical Indoor 7 Day Timer
IS THE TORK TIMER MODEL W200 A DIRECT REPLACEMENT FOR THE PARAGON 7007-00
  • 52 Answers
SOURCE: Paragon timer parts
electricalexpeditors.com
Posted on Oct 05, 2009
  • 52 Answers
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Posted on Dec 30, 2009
HVACjake
  • 22 Answers
SOURCE: I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Posted on Jan 21, 2010
  • 52 Answers
SOURCE: paragon timer part
visit electricalexpeditors.com
we sell replacement parts
leave all info on the contact page
thank you
Posted on Jan 27, 2010
SOURCE: I need trippers for an
I don't recognize Paragon TC-2.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic cross reference does not have that model number either.
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Paragon sent e-mail last month saying they were no longer making timers and parts, except for defrost timers. Your water heater timer is not defrost timer.
Here is a wide selection of water heater timers, electro-mechanical and digital:
http://waterheatertimer.org/Boxtype.html
Manuals and wiring diagrams are shown for most products on page.
I recommend simple 240Volt Intermatic WH-40 for price and reliability. Drawback is minimum 1 hour on-off.
Or Intermatic T-101 for 120Volt heater or T-104 for 240Volt heaters sold at Lowes.
Intermatic trippers and motors are available and interchangeable, and are made of steel.
Some new timers are made with plastic parts:
GE 15207 is universal 120V 240V and sold at Home Depot.
Tork has new universal electro-mechanical timer, TU-40 for 120 and 240 applications
I use GE 15070 in-wall timer from Home Depot for my water heater because I change times frequently and try to shave every dollar:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
Add a comment if you need more help.
You can also take advantage of fixya phone support.
Fixya expert will walk you through any problem for a price.
Posted on Dec 23, 2010
4001 0 timer c1878
Paragon no longer makes timers, except for commercial defrost series.
There is a cheap knock-off that looks like the old 4001, but I cannot find seller any longer and do not recommend.
Instead, order 120Volt Intermatic T101 timer to replace Paragon 4001.
Or order T101R for indoor-outdoor weather-tight enclosure
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
http://www.amazon.com/dp/B00002N5FN/?tag=waterheaterti-20
http://www.amazon.com/dp/B000BVZB3E/?tag=waterheaterti-20
Paragon 4001 terminals are 1-2-3
Intermatic T101 terminals A-1-2
Paragon terminal 1 Hot goes to Intermatic terminal 1
Paragon terminal 2 Load goes to Intermatic terminal 2
Paragon terminal 3 Neutral goes to Intermatic terminal A
Intermatic makes replacement clock motors and trippers for T100 series, so this timer will last decades.
Tork also makes a line of mecanical timers sold through home depot under GE brand name:
http://waterheatertimer.org/GE-timers-and-manuals.html#15145
These are also good timers, but lighter construction than Intermatic T101.
Gene
h
Aug 23, 2013 | Paragon Hardware & Accessories
How tio wire a tork model ejwt timer
Tork EJWT is percentage cycle timer that was formerly manufactured by Paragon and sold as the Paragon E500 series interval (cycle) timer
Copy following link for clear Tork EJWT wiring illustration
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle-timer
Jul 18, 2012 | TORK Digital Interval Timer Ssa100r-24
Moved time pointer on pool timer to set time than read instructions moved pointer back to original spot now timer does not click on or off when it passes pins
Timer brand and model number are not shown.
Brand and model appear on inside of timer door.
Moving stationary pointer will not affect on-off operation of timer. The pointer is just reference for setting current time.
Worn trippers can cause problem.
Trippers are softer metal and designed to wear down so timer mechanism lasts for decades.
Intermatic pool timers use set of 156T1978A trippers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Tork timers use P47 tripper on 24-hour clock dial
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
Paragon 4000 series uses X2772 tripper. Paragon timers are discontinued and trippers hard to find.
Open following links for different timers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Aug 01, 2011 | Hardware & Accessories
The micro switch is bad and i need a new one...where can this be purchased?
1) Paragon is no longer making timers and parts except defrost timers.
You posted under JW-30-00 series cycle timer, which is not a defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#JW
2) JW timers are still sold on internet. Some Paragon timers are still being sold, and other manufacturers will continue making various Paragon products under new names.
3) Intermatic cross reference shows CT1000 is replacement for JW-30-20
http://www.intermatic.com/~/media/files/intermatic/products/sell%20sheets/time%20switches/ct1000%20sell%20sheet.ashx
4) Tork makes the ACT series cycle timer
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Paragon JW-30-00 Percent Cycle Timer
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
The 120 volt power for the timer motor has two terminals. One if labled M the other is labled T. Which one is the hot and which one is the neutral? Thanks
There are a lot of timers out there.
Add a comment with brand and model number to give us a shot at finding the information.
You posted under paragon 7008-00 timer
7008 is 120V timer with 120V clock motor
Power lines connect to Terminals A and B
Going through Paragon timers, I don't see terminals M and T
Looking at Tork timers, I dont see terminals M and T:
Looking at GE timers, I don't see M and T
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
Woods timers, Sylavania timers don't have M and T
Intermatic makes more timers than I can go through in one night, but I don't recall M and T terminals.
Nov 19, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Replacement timer motor needed
If you have Intermatic timer, then clock motors are available for most hard-wire box-type timers. Most pool and spa timer modules are available or have same/similar replacements. If you have plug-in timer, including power pack or portable outdoor timer or indoor plug-in or in-wall timer, then no clock motors are available.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
If you have Tork timer, then clock motor is available for 1100 series.
If you have Paragon timer, clock motors will be hard to find
If you have other brands of timer, then clock motors are not available except Deihl, DIGI and Grasslin timer modules, but post brand and model number of timer so I can search my files.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Sep 11, 2010 | Intermatic WH40 - Water Heater Time Switch...
Paragon 7007-00 Electromechanical Indoor 7 Day Timer Logo
49 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
