Question about Weather King 12AJA6001AH Air Conditioner
I NEED A SCHEMATIC FOR AN ARMSTRONG AIR CONDITIONER MODEL # MDE30-10D2F-4
MY ARMSTRONG AIR CONDITIONER LEAKS WATER IN BASE OF UNIT
Your drain line is clogged with algae. unclogged it using solution with sodium hypochlorite or hydrogen peroxide.
Jul 27, 2012 | Armstrong Air Conditioner Conditioning...
What is a concept 10 air conditioner?
"Concept 10 High Efficiency The SCU10 Air Conditioner (10 S.E.E.R) is the entry level model of the Armstrong line of Air Conditioners."
Hope this helped you. Thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
How do i find coil size for a armstrong central air unit
Are you asking what indoor coil size you need to match your outdoor unit? If so the model number of the outdoor unit will have a number divisible by 12. example an 036 is a 3Ton a-c an o42 is a 3 1/2 Ton. Probably the numbers right after UAMB.
Aug 27, 2009 | Ruud UAMB Air Conditioner
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Weather King 12AJA6001AH Air Conditioner Logo
150 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
