I have a 1998 Ford Mustang GT. The car will start and stay running for about 1-2 minutes, then it will quit running. I did a fuel pressure check and at initial start it is at 40 psi and after it starts it drops to 30 psi. after about 1-2 minutes, the fuel pressure starts plummeting down until it reaches 0 psi and shuts off. I have replaced the fuel pump, the cam shaft sensor, the crankshaft positioning sensor and the fuel filter!! Any ideas what can be causing this problem?
  • 15,935 Answers
Fuel pump or ECU is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
1990 mustang gt will not stay runing have to give
check the fuel pressure with a gage and check the fuel volume as if either one is bad can cause this problem.
Sep 21, 2014 | 1990 Ford Mustang
1994 mustang gt auto trans keeps stalling while
replace fuel filter and if it continues have pump pressure checked
Sep 09, 2014 | 1994 Ford Mustang
1994 mustang gt auto trans keeps stalling while driving sometimes just when warming it up. Check engine light does not stay on when running. Replaced dist, rotor, cap, coil and had ignition module tested....
check for a fuel flow problem( pump pressure-filter blockage-injector/s) run fault codes ( check for HO2S and O2S sensor operation.. Check cat converter is serviceable Blocking exhaust system
1998 mustang hard starting.
Hi, Needs a new fuel pump sorry to tell you. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 24, 2017 | 1998 Ford Mustang
How to bypass security on a 1998 ford mustang gt? it will turn over but will not start, no fire, and fuel pump will not come on
you need to have the key reprogrammed to your car. a plain key with no chip will not start the car. it might start, but it won't stay running .
Apr 01, 2011 | 1998 Ford Mustang
1998 Mustang GT sat for over 2 years. 1/4 tank of fuel. Went to drive it and wont run off idle and dies on idle, won't start. Replaced Fuel pump, Fuel filter, Put in fresh gas with octane booster and ran...
Injectors need cleaning, As being left for time its got dirty, Run a fuel system cleaner through the fuel, Or get an professional to clean injectors for you with a high pressure unit.
Aug 11, 2010 | 1998 Ford Mustang
1998 Ford Mustang V6 engine knocks and wont stay running
No, but you can bend connecting rods with ether.
May 04, 2009 | 1998 Ford Mustang
I have a 1991 Mustang GT, and it runs awhile but goes dead,I have replaced the fuel filter and that did not stop the problem. The car runs about 5 or 6 minutes but shut down and will not restart, but will...
test the fuel pressure first. use a guage and watch it till engine dies. also the guage has a bleed off hose, run a small amount of gas into a cup and check for water
Apr 06, 2009 | 1999 Ford Mustang Cobra
Have you checked fuel pressure regulator.Getting fuel out of injectors? Did you replace old pump with a new good quality pump?
Sep 26, 2008 | 2003 Ford Mustang
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
