Question about Hitachi Televison & Video
L46VFO4U WALL MOUNT INSTRUCTIONS
2 Suggested Answers
markevans
  • 148 Answers
SOURCE: wall mount
wall mounts are designed to fit most every unit.
some have locking tabs on the bar that stops them from bouncing off during an earthquake. it makes it harder for someone to walk away with your set.
try frys electronics depending on where you live, or hometech.com, or radio shack. other home electronics stores have them. even wallmart.
good luck
mark
Posted on Dec 28, 2007
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
What size screwsare used to attach wall mount
Wall mount for what size TV?
The answer is probably in the instructions that came with the wall mount.
I need: Size of TV.
What kind of wall you want to attach this TV to.
Remember, I am far away and can't see what you are doing.
Aug 19, 2014 | Televison & Video
How do I wall mount the phone
Most new phones come with a special wall mount bracket included in the box.
If you no longer have this bracket then you may be able to order a new one similar to the one advertised at the following link:
http://www.nec-dsx.com/nectewamokit.html
Good luck.
Joe.
Nov 22, 2011 | Lands Phones
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
We have no instructions for the wall mount on the entertainment system that we are using with the lg47le5400 tv. I would like to know what hole we use and what screws to mount it. we recieved no...
the wall mount should have came with the proper screws to fit the back of your tv, if the screws fit the mounting holes on your wall mount, fit the larger screws that came with your tv through and make sure its tight, if so it should work.
Jun 26, 2010 | LG 47LE5400 47 in. TV
Can i mount my tv on the wall it is model cwf32l6
Yes you can.
there are many types of wall mounts you can buy. Ensure the load / weight rating of the wall mount exceeds that of your TV, and mount it exactly as per the manufacturers instructions.
Most audio visual shops sell all types of wall mounts.
You can also check out ebay.
Feb 28, 2010 | Symphonic ST419E TV
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
May 15, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
