Question about LG RUMOR Cellular Phone
Why doesn't my USB adapter read my 4GB MicroSD
I purchased a Duracell 4GB MicroSD that came with an SD, MiniSD and USB adapter, The MicroSD works in my phone and in the SD adapter in my camera, but NOT in the USB adapter in my PC.
Any suggestions?
  • kkelly_75 Jan 06, 2009
    I have a problem with my Duracell MicroSD 4GB. It works in my phone (LG Rumour) without problems, but neither my PC or my MAC will recognize any of the included adapters. Any ideas??
  • anime13 Jan 20, 2009
    my stupid MicroSD memory card works in my phone (LG RUMOUR) but it won't frickin work in my microSD adapter.i put in my computer with the memory card in it. i put it into the right place it says SD on it and it fit but the stupid computer say's "the request could not be performed because of an I/O device error". WHY WON'T IT WORK ON MY COMPUTER!!!!?????
So all in all it was pointless buying an adapter if you have to turn around and spend 30 dollars on something to read it.. i just end up using my old mp3 player that has a external slot for microSD's and hook that up to my computer and transfer files that way
Posted on Jan 27, 2010
You may need to upgrade to a MicroSDHC card reader for your computer. My computer couldn't read the MicroSD cards I was using in my Rumour phone either, but this solved the problem. You can purchase these upgraded card readers that plug into the USB port on your computer for around $30.
Posted on Jan 21, 2009
Unlock software
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the microSD/miniSD adapter. The SD adapters will also have a lock switch.
Sep 12, 2013 | SanDisk 2GB microSD Memory Card
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
What mini sd card fits my polaroid 4 gb media player model pmp280cb-4
It will take any MiniSD Card or you could get a MicroSD Card with a MiniSD Card Adapter.
Just do a search on Amazon for whatever size Mini SD Card you want (4GB, 8GB, or 16GB).
Jun 26, 2011 | Audio Players & Recorders
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
Micro sd card is locked how can i unlock this ?
For the microSD card you'll need the large adapter (picture left side)
to unlock.
Insert the microSD card into the Adapter with the arrow upwards:
put the microSD card directly into the Adapter on the left.
(The Adapter on the right below is miniSD, used for other size cardreader slots)
4. Try to put data onto the SD card (Adapter) with the microSD card in,
on the SD card reader slot of your computer
or
Pull out the microSD card and put it in your previous used device, to
see if transferring files will work.
Jul 15, 2010 | SanDisk 2GB microSD Memory Card
Is the smallest chip an adapter as well?
The smallest card pictured there is a 2GB microSD card, which is an actual memory card. The biggest is an SD adaptor the microSD to fit into and the second biggest is a miniSD adaptor.
Dec 31, 2009 | SanDisk 2GB microSD Memory Card
I can not fint memory card in my PC
if you have a microSD card, and a miniSD Card slot, you'll need a SD card adapter that the microSD card can fit into, and is the size of a miniSD card. SanDisk makes them.
May 17, 2009 | SanDisk 4GB microSDHC Memory Card
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Micro sd 4gb micro card.
Guaranteed solution!
This is from Duracell Support
Unfortunately, we have found an incompatibility with a new revision of our microSD and the USB adapter that accompanied the card you purchased. We are in the process of solving the compatibility issue. We are truly sorry for the inconvenience and would like to send a new card that is compatible with your USB adapter. Your original card should be functional in other adapters, phones, and cameras. The microSD card's compatibility problem should only exist with that USB Adapter. For your inconvenience, there will be no need to ship the original microSD card back to us so feel free to keep and use them both. We would also like to send you two free music downloads from Duracell Flash Memory.
If you would like to take advantage of this offer, please let us know your full name, address, the size of the microSD, and the name and location of the store from which you purchased your microSD. When we receive your information we will ship your replacements parts and music downloads immediately.
Best Regards,
Duracell Flash Support Team
Here is how to reach them:
http://support.duracellflash.com/ics/support/default.asp?deptID=5612&ticketID=7688933
Jan 04, 2009 | LG RUMOR Cellular Phone
Does not read from adapter
then it must be password protected.Delete the password of micro SD from your cell and then try.........it must work........
Apr 16, 2008 | SanDisk 4GB microSD High Capacity Memory...
LG RUMOR Cellular Phone Logo
1,917 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
