Question about Canon PIXMA iP3000 InkJet Photo Printer
Just installed new printhead
Didn't callibrate dont know how to fix
    President:
  • 8,637 Answers
Go to Control Panel and click on printers. Then right click on your printer, then click on MAINTENANCE when the window opens, click on PRINT HEAD ALIGNMENT. Next the window will come up to START PRINT HEAD ALEignment. Follow the instructions from there. Hope that will help you get it fixed. Bud
Posted on Jan 07, 2009
Hp Business Inkjet 2800 printer prompted me to change the cyan printhead. I changed the cyan printhead and it is not detecting the new printhead. A printer repairman came to inspect the printer and...
Hi
Did you check the connections in the carriage if there is little amount of ink on the contacts? if not then clean it well with a dump cloth and try to re-install the old printhead it will sure accept it. If not then the other way is to change system date of the printer first and then try again.
DO RATE MY SOLUTION
Jun 30, 2011 | HP Business InkJet 2800 Printer
I have taken the printhead out and cleaned it like the screen told me to do it. I have even turned on and off the printer, and when that didn't work I disconnected but still it didn't work. I...
It could be due to an outdated firmware version or a poor connection between the printhead and carrier contacts. Please follow the steps below to fix the problem:
1. From the printer control panel, touch Ink Levels > More Options > Replace Printhead.
2. Open the printer cover. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Press the tab, and lift the latch. Pull up to remove the printhead. Close the printer cover then turn off the printer/unplug the printer from the power source.
4. Turn the printer back on. It will ask you to "Open Cover to Install the Printhead". Press the Home icon. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to http://bit.ly/p905fw.
6. Once the firmware update is successful, firmly re-insert the printhead.
If problem continues, please contact Lexmark technical support for additional assistance.
Jun 16, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My board will not callibrate to the wii and i dont know why. it doesnt give any reasons why it might not callibrate the only thing i can think of is that we dont have 4 ft radius each way, which really...
try using two old batteries and two new batteries, also why calibrating try putting the board on a small stool - this worked for us. Good Luck!!! by the way our room is really tiny and there is hardly any space around the board.
Dec 25, 2010 | Activision Tony Hawk: Shred
Hp printer is printing mirror image backwards. How do I fix?
go to control panel>printer> right click properties> seach the tab thet shown the image printed is rotate or not and set it by default
Dec 03, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
How do I calibrate the printhead
you should et a message, if you dont push menu and look for printhead alignment or something like that
Jan 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
New cartridges no print
You may need to contact kodak and have the printhead replaced
Jul 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Jul 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
Thanks,
Carol
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Callibrating after every job
With the printer on remove the printhead and turn the printer off. Turn the printer back on again without the printhead and let restart. Once the printer has finished the startup process reinstall the printhead. Let us know if that works and please don't forget to rate this posting.
Mar 02, 2007 | HP Inkjet 1200dn Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
60 people viewed this question
old marine
old marine
