Question about Kenmore 24 in. 15932 Built-in Dishwasher
No water The washer was working fine, but now it says it's running through the cycles, but no water? I made sure the water line going in was good. Could it be the little pump that connects to the water line?
  • ruthanncoven Jan 15, 2009
    The clean light is blinking and I cant get the start button to activate a new cycle?
  • G4RC Jan 27, 2009
    I have the same problem. checked the kines in and all are good, checked the wiring for the inlet solinoid and it seems fine too.
  • 2,120 Answers
Maybe the solenoid that lets the water into the DW is not actuating
Posted on Jan 06, 2009
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
My Frigidare Affinity front load washer doesn't pump water on the Normal cycle.
Check the water inlet electro valve at the rear of the washer and make sure it is working.
Jul 25, 2017 | Frigidaire Washing Machines
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
Cold water doesn't run into washer on any part of the wash/rinse cycle. Checked cold water line but not plugged uphecked back of washer where water line connects and no clog there either. Makes a...
Sounds like the valve isn't working properly.
One way to test is to turn off the water supplies and at the back of the machine switch the hoses.
Turn on the water and see if you get cold and not hot . If so replace the valve assembly
Jan 23, 2011 | Maytag Washing Machines
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
"LF" Long Fill Fault Code on Whirlpool Cabiro HE Washer
there is an electronic timer, did they mention how long the fill should take on average and when the timer signals fill time exceeded?
Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Washer flashes F20 on the cycle status. motor is running , door is locked, NO lights are on. Clothes are in washer. Help
my washer just did the same thing... just fixed it... take top cover off....look where your water comes in .. just past the valves u will see a little device in the line where the water goes into the detergent... take that off.. clean it... run water through it.. blow air through it.. make sure it spins.. put back together and hopefully it works... worked on mine.. good luck
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
52 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
