Question about Pentair 2.0 Hp Whisperflo Pump
If I open my whisperflow pump, do I have to replace the seals?
Can I put it back together without replacing the seals or is that obligatory to do so?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
No you can put it back it should be ok
Posted on Sep 07, 2014
2 Suggested Answers
  • 366 Answers
SOURCE: 1hp whisperflow pump, seal change. How?
Make sure breaker/power to pump is off. Remove the six bolts holding the wet end to the seal plate. Remove the diffuser to expose the impeller. Remove the screw in the middle of the impeller by turning clockwise (left hand threads). Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. Once the impeller is off, remove the four bolts holding the seal plate to the motor. Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. Apply a thin coat of lube to the seal plate and impeller where the new seal will go. Remove the new PS1000 shaft seal from the box (being careful not to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
It is a good idea to replace the tank o-ring when taking to pump apart, but if the o-rings are in good condition, just apply a light coat of lube and reuse them.
This is a general guide for replacing a seal, if you have trouble removing the impeller, you may need an impeller wrench and a tool to hold the motor shaft.
I hope this helps, if you have any specific questions, email me at mail@leisurepoolservice.com
Posted on Oct 28, 2009
If I open my whisperflow pump, so I have to replace the seals
if seals leaking probably ruining bearings replace whole unit less headaches
Nov 07, 2012 | Pentair 2.0 Hp Whisperflo Pump
Whisperflow pump making loud squealing noise
The noise is likely either the seal or a bearing in that order. If you are mechanically capable of working on the pump yourself then you can purchase a seal and gaskets at a pool supply store. If the bearings are bad then the motor needs to be replaced. In some cases a bearing can be replaced but usually it is more work than it is worth.
Aug 09, 2011 | Pentair 1 hp WhisperFlo InGround Pool Pump...
How do you replace a seal on a Sta-Rite pool pump? How do you remove the old seal? Ceramic and graphite.
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Aug 14, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
My Hayward super pump is leaking water where the two large sections come together with six 9/16 bolts at the very top. I replaced the large flat rubber seal and even tried silicone on the faces that come...
Take the two sections apart, remove the seal and put the two sections back together.You will be able to see any gaps if they are warped. A straight edge might work too. Also inspect the surfaces for any cracks. The can get a hairline crack if the sections are tightened to tight, and the seal is out of the grooves. If all is ok, silicone the seal, silicone the grooves, then put the pump back together. This will help keep the seal in place. I just use a pool/spa sealer like Leslies Pool and spa lubricant.
Jun 26, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
GE Model GSS25RGMA WW - water dispenser pump leaking - appears to be 2 pumps lower left in back - got a replacement from dealer - put it back together and found leaking at hose connections - question about...
You may not have the tubing pushed in all the way. If you can pull the tubing out without depressing the ring around the tubing it's not in all the way. This is a self sealing connection but only if the tubing is seated properly.
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Leaking front pump seal for a 2002 tahoe
You need to remove the transmission in order to replace that seal. Many times the seal leaking is an indicator of another problem such as a failed pump bushing or metal in the fluid from somewhere else in the unit. i'd definitely take a look in the pan before considering doing the seal as the unit may need to be rebuilt. If it's working normally and the leak isn't bad yet (only a slight drip when running) you can try a good conditioner/sealer such as Lucas. Nothing will replace worn parts but it can buy you some time.
Without proper equipment such as a transmission jack the job becomes far more difficult than it needs to be as in essence it involves just a lot of unbolting things attached, then putting it all back together. (with right stuff, under 2 hours...without, up to six days.(depending on how fast you work.)
Can't give you a guide for that, it would take several pages! (get a manual for reference if you need it...only about $20)
Good Luck
Jan 24, 2010 | 2003 Chevrolet Tahoe
Need to put in new bearing, it is really starting
Bearing on new motor failed for some reason, Make sure the new one will last, check that all shields and water deflecters are in place and that pump seal is not leaking. New motor bearings should be sealed but water has a bad habit of getting into anytging we try to keep dry.
I recomend replacement of pump seal whenever pump is opened and impeller is removed, cheep insurance. Take your time and make sure everything is clean as it goes back together, don't lubricate the pump seal faces, the ceramic faces are designed to be self lubricating and anything (even fingerprint oils) on them can cause a leak.
Aug 01, 2009 | A.O. Smith SQ1102 Pool Pump Motor
How do you change a pump seal on a hayward 1hp pool pump
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
May 13, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pentair 2.0 Hp Whisperflo Pump Logo
56 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
