Question about Dell Latitude D600 Notebook
Can't recognize the wireless router
How can I tell if my Dell D600 is wireless ready? I have loaded the drivers and set-up the router. The "find wireless networks" option does not show up under Network connections.
  • japowell Jan 05, 2009
    I know there is no wireless icon in the tray. I will have to check the hardware tab tonight. Can you tell anything about the missing icon?
    When referencing the control panel; could you tell me what to look for in XP?
  • 37 Answers
Here's a few things you can try:
1. You should see the wireless icon in the system tray, bottom right of screen (tiny computer with rays to the right of it)
2. Try the correct wireless function key: hold down Fn key and press the F key with wireless mast picture on it. (possible F4 or F8). This will turn on and off the wireless card.
3. Check if wireless card is installed in Device manager as follows:
click on Start, Control Panel, Performance and Maintenance, select System, then Hardware Tab. Click on Device Manager.
Expand "Network Adapters". You should see a wireless card listed. If not, you've installed the wrong wireless driver...
Uninstall the one you installed and look for the correct one on Dell site.
Posted on Jan 05, 2009
Please what is Wifi and where can i find the button to turn it on or off.
WiFi is a wireless connection, if you have a wireless router and it is connected to the Internet, then you can connect to the Internet using the wireless card in your D600.
If you don't have a wireless router, then you can connect to the Internet at a free WiFi hot spot at locations such McDonalds, Starbucks and the airport.
This model D600 may not have a wireless card installed.
If it has it will be an Intel {ro wireless card. Check the Device Manager - Network Adapters, if you do not see a wireless adapter then you do not have a wireless card installed.
If you have a wireless card and the wireless driver is installed the you are ready for wireless connection. There is no button to turn on the wireless card, it will be ready to use.
If you require information on setting up your own wireless network, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 09, 2010 | Dell Latitude D600 Notebook
I have a Dell Lattitude D600 that is not recognizing the ethernet cable plugged into it. I went to "Network Connections" and noticed that there is only a wireless connection and not a LAN. In the deviced...
Yes, LAN is different from the Wireless network.
Chances are, the driver for the ethernet card is not yet loaded or somehow got corrupted.
What you can do is to get the install disc or acquire the correct ethernet driver from Dell's support website. Install it into your PC and then let us know if you need further assistance.
Nov 19, 2009 | Dell Latitude D600 Notebook
My dell latitude d600 is not recognizing any wireless connections. I believe the switch is at top of the keyboard and it doesn't seem to be working. Any advice
if it is not seeing any wireless networks, the wireless card may be defective, try having it tested, or check the device manager to make sure the drivers are installed correctly for the wireless network adapter
Jun 27, 2009 | Dell Latitude D600 Notebook
No wireless network signal on dell latitude D600 laptop
You will need a wireless router or wireless modem.
Not all ISP's provide modems with Wifi (wireless)
Can you tell us more on what specific hardware you have? and have you connected before?
Apr 16, 2009 | Dell Latitude D600 Notebook
Need WPA2 wifi connection to my Linksys with Dell D600
The WPA settings on your wireless card must be the same as the setting you configured on your wireless router. This allows your wireless card to communicate with the wireless router.
Apr 07, 2009 | Dell Latitude D600 Notebook
Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
Apr 04, 2009 | Dell Latitude D600 Notebook
Bad Wireless Connection
This is usually caused by a driver glitch. From the device manager, uninstall the drivers for the wireless, then reboot. The machine will find and reinstall the drivers. If the problem persist, the take the card out, clean the connections, and reinstall it. It's located under a panel on the bottom of the machine. If it still won't work, then you need to replace the wireless card.
Jun 26, 2008 | Dell Latitude D600 Notebook
Dell D600 - Linksys wireless router/adapter
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in 192.168.1.1 into your web browser and a login in screen should pop up.
Apr 28, 2008 | Dell Latitude D600 Notebook
Wireless card not recognized
Make sure you are using the latest driver and software for the card. If you haven't already done so, I would also suggest trying the card in another computer, and a known good card in your D600, to see if the problem stays with your computer or follows the card. If it follows the card to another computer then it is most likely a problem with the card itself. If other known good cards also fail in your D600 it might be something with the D600 card slot. If the slot is the problem then I would recommend contacting Dell tech support. Larry Dell Customer Advocate
Apr 11, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
192 people viewed this question
Alun Cox
