Old TV can't scan for cable channels
I have an old Fisher TV and can't figure how to get it to scan for all cable stations
  • fj_gray Jan 05, 2009
    It goes up to 40, then jumps to 95
  • 179 Answers
It depends on how old the set is. some of the older sets would only go as hi as channel 120. some really old sets only went to 36 on cable. how high do the numbers go?
Posted on Jan 05, 2009
  • ken black Jan 05, 2009
    it is an old set with no upper cable channels then. sorry
I want to hook up my old 1992 Sylvania TV to HD Antenna, but I cannot figure out how to scan or auto-program the channels. Model SRC1351 101
Hello... Somewhere in the same menu as the Air/Cable setting should be an option to scan for channels. It might be called Auto-Program, or something similar. The bad news is that: "On June 12, 2009, the Federal Communications Commission (FCC) mandated that all U.S. based television signals must be transmitted digitally." Since your TV was manufactured in 1992, it isn't capable of detecting or displaying digital channels. If you're really fond of the TV, you will need some sort of conversion box. If you can afford to, I'd recommend buying a new TV, and get the extended warranty. I hope this helps!
Nov 26, 2017 | Sylvania Televison & Video
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more :
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
Read more :
good luck
Jan 08, 2015 | Televison & Video
No channels scan in
you have to use an old fashioned set of tv top rabbit ears with a uhf loop just like the good old days if you have cable hooked up it will not work..
Nov 08, 2009 | Hauppauge WinTV-HVR-950Q TV Input
Lost some stations on my Sony lcd TV.
It is a possibility if you are using a cable tv service, without a converter box, that the cable company has limited the number of station you are able to receive. It seems to be their new ploy to get subscribers to get a box since the digital changeover. I also may be that the TV's tuner memory may have to be re-programmed. Go into the menu and go through the channel scan process and see if they return. If they don'y it may be a tuner issue. An easy fix is to get a cable box!
Hope this has been helpful
Jul 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
PROSCAN 26" LCD TV with DVD won't show all the channels
bought 26 in pro scan tv can't figure out how to connect dvd player,craziest thing i've ever seen.please help
Mar 14, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Digital channel numbers are different
The channels for a digital stations are really just "names". Thy will be the number for the old analog channel followed by a "-" and a number 1 through 4. The actually frequency can vary
from the old frequency. You can see this at;
To set up your tv, you will have to connect your signal source (Antenna or Cable) to the set.
Go into the menu and select the Signal source (Channel) to match what you connected.
Go into the menu for scan or auto program and SCAN in the channels in your area.
Now you can watch the stations on your set.
If the broadcast frequency of any station change, you can re-scan it in again. The "name" will not change so the change will be invisible to you.
Feb 25, 2009 | Vizio L32 32 in. LCD HDTV
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
Television will not air all cable stations
If when you turn it on it starts to run through the stations let it go and finish.
Nov 18, 2007 | Sylvania 6719DF 19" TV/VCR/DVD
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
