Question about Daewoo Televison & Video
Daewoo DSL19V1WD digital tuning
I have had my TV aerial changed to pick up a different receiver. I've tried retuning but that appears only to have attempted to find analog channels, but of course there aren't any. i've tried resetting the tv to factory settings but that didn't help. is there any way of forcing a digital retune?
4 Suggested Answers
vortash
  • 431 Answers
SOURCE: Cannot tune analog channels on Bush 32'' LCD TV
Hi I am Vortash not a set I have worked on but suggest that the solution will be in the user manual , if you have no user manual try this site http://www.safemanuals.com some of the downloads by adobe pdf file are free others reasonably priced I hope this is of help Regards Vortash
Posted on May 15, 2009
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Posted on Dec 06, 2009
SOURCE: I have a Daewoo DSL22V1WCD combined tv/dvd with
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Posted on Jan 02, 2011
Initially looking for logik spport logik tv support. cannot now tune in tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
Retuned my humax box and my west channels are now wales how can i change them back
You will need to manually tune to your preferred transmitter. The Humax will tune to the first decent signals it finds, so if signals from the Welsh transmitter are good and found before the transmitter you want, it will use them.
Or, you may be able to unlpug the aerial, start the auto retune, then replace the aerial after about 25% of the scan completes. You may need to adjust the % before replacing the aerial to ensure that only (and all) wanted channels are received.
Sep 03, 2014 | Humax Televison & Video
My 32inch Murphy LCD TV can not find the new
This could be a problem to do with your aerial rather than the TV. However, your first action should be a "Factory Defuault" reset. Make sure the TV does a full retune rather than just looking at the channels where the stations were previously.
The TV will have a flat response through the channel frequency range. Your aerial though could be a very different matter. Depending on the type of aerial, and especially if it's a banded aerial that discriminates against certain frequencies, then the retune may well have moved certain channel into frequencies that your current aerial really struggles to pick up.
You don't say what your TV region is, so I can't be specific because you didn't give the necessary information in the question. But I'll give you an example based on my region which is North West England, receiving off the Winter Hill transmitter.
Anyone with a Group C/D banded aerial will be okay picking up most of the channel muxes because they're grouped up at the top end of the frequency range (ch 49~57). That's pretty perfect for a C/D aerial. However, the new Freeview HD channels that give BBC 4 HD, 4 +1HD, BBC News HD is down at ch 37. A C/D aerial will struggle to pick that up because it is far less sensitive at that frequency, and particularly so if it is a contract Yagi type aerial.
The majority of aerials fitted though are the so-called Wideband High Gain. These favour the upper end of the frequency range again. So channel 37 will be picked up. But is is much weaker than the other muxes.
Sep 03, 2014 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Technika TV Tuning Problems
hi the same happened to mine. a22inch freeview dvd.wont pick up a signal when tuning in.Its had very little use ( 150hrs ish) as its in our caravan. we now plug in a separate freeview box via the scart.Tesco dont want to know as it was 3months out of warranty at the time of complaint.Anyway Im meeting Tesco in County court in july. It appears to be a common fault
May 13, 2010 | Televison & Video
I have a DMR-EZ25EB and sometime after the freeview retune last year I realised I had not retuned. I retuned as per the instructions (and have done so several times since) but I have lost all my freeview...
This is not related to your aerial as you have good reception with your TV. Some receiving units (i.e your DVDr) need the channel memory to be cleared before the re-scan is done. Otherwise the scan gets corrupted.
To resolve this do the following;
1. Remove the aerial from the equipment and leave unplugged.
2. Go to the menu and select rescan or retune. It’ll take a few minutes, but when it’s done, it should say ‘'no channels found’.
3. Disconnect the equipment from the mains power supply and leave it un-plugged for 30secs.
4. Re-connect both the aerial and the mains power supply and switch the equipment back on.
5. Go to menu again and select rescan or retune. You should now have all the channels available to you.
I believe this should resolve the issue for you. If so please do take a moment to accept my solution otherwise it will not credit to my ledger.
Thanks for using FixYa.
Jan 18, 2010 | Panasonic Televison & Video
I have tried tuning in my dvd recorder in the reset menu, but after the scan process a message appears "Check aerial connection. Help, what am I doing wrong?
make sure aerial is in dvd recorder press functions move down to others press enter move down to setup and enter highlight tuning move right and down to auto setup reset and enter
tou will see a warning message move to yes and enter the dvd recorder will start tuning and a list of all the stations that been found will be displayed after that it will start to scan for analog stations( BEEN TURNED OFF) once finished
picture will be displayed
if no list was seen when tuning in digital stations then make sure dvd is digital
and to check aerial put direct in to didgtal tv and retune tv
Dec 16, 2009 | Panasonic DMR-ES10 DVD Recorder
Oct 31, 2009 | Televison & Video
Cannot get any digital channels since local digital switch over
The official line on this is that you should try and retune again, but there are some Panasonic models with similar model numbers to yours which have been specifically identified as having incompatibility problems with the Freeview retune.
However, your model is definitely not one which appears on the problem list, so it's worth checking that your aerial wasn't misaligned or damaged during the gales last weekend. In addition the Winter Hill transmitter is currently undergoing work until December which will significantly boost the digital signal and give it HDTV capability, so your box may have have been knocked out of kilter if the current digital service was temporarily operating at restricted capacity. Digital signals are by their nature much weaker than analogue tv and if you have a marginal aerial system which has been up for many years and which feeds a number of televisions in the house then it's definitely a good idea to see about upgrading your aerial system.
The difference in actual parts costs between a top spec aerial system and a poor one are surprisingly low, it's also easily possible with careful design and installation to get a better performance with poor parts than you can get with a poorly designed and installed system using top quality parts. One thing does hold true though: a well designed and installed system using poor parts will only last a few years before needing serious attention but a proper job can last up to thirty years.
If you're sure about your aerial system and retuning does not help, then you'll need to contact Panasonic directly. The first web address below will give you their contact number along with a list of Freeview boxes with known retune issues. A second web address which I've given takes you to an excellent Sheffield based tv aerial company which has an incredibly informative website.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
http://www.aerialsandtv.com/index.html#ATVinfo
I hope that you've found my answer to be helpful and ask only that you return the favour by rating my answer.
Oct 05, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
