My furnace is to loud - Heating & Cooling
  • 659 Answers
Make sure you have a clean filter and the blower assymbly is clean. If there is too much torque on the motor, it can cause noise issues.
Posted on Jan 05, 2009
New Bryant. Why isn't it heating home well?
The furnace capacity could be inadequate
Your home could have a serious cold air infiltration problem
Your home could have inadequate insulation
If the new furnace was installed and the old thermostat was not replaced, it may be the source of the slow heating
If the new furnace was connected to existing ducts, they may be inadequate. This could account for the loud fan
Dec 25, 2015 | Heating & Cooling
My furnace makes a loud noise on start up
What kindof sound? Is it a squelling kind of sound?
Jan 03, 2013 | Heating & Cooling
We have an Intertherm furnace in our manufactured home which is apparently a replacement furnace as this is not the brand showing on the original paperwork for the home. Problem is that it is very loud. ...
That is a common furnace for manufactures homes and yes they are loud....that is because there is no return duct on the unit and the fan sits jsut inside the door so the noise is not contained...
short of moving the furnace there is not much you can do about it...yes it stinks I agree with you... wish I could give you better news...
heatman101
Aug 08, 2010 | Intertherm P3RA-048K Air Conditioner
My cozy furnace makes a loud clicking noise every time it is running. What can I do to fix this problem?
Wall furnaces sometimes do that it is just expansion and conttraction of furnace. rus
Mar 17, 2010 | Heating & Cooling
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Noise
I have installed a ton of Kelvinator furnaces. I have NEVER heard a loud one. The installer should cooperate. Call your building inspector. I bet this guy did not even pull a permit. If it is the burners that are loud then have your gas pressure checked in the furnace. Do you have a noisy induced draft motor. If so replace it.... you are under warranty.
Start calling your installer every night at 3 am. Call him every time you walk by a phone. He will get the hint. You need to as loud to him, as your furnace is to you.
Call Kelvinator... you can get the number on line. tell them about your problem they do not want bad advertisement. they will find someone to solve your problem.
Good luck....
Jan 01, 2009 | Heating & Cooling
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
FURNACE RUNNING LOUD
sounds like either the motor is off balance
or is going bad again
either way id be on the phone to the guy who did the rapair
more than likely the set screw on the sqiral cage came loose and now its vibrating
Nov 11, 2008 | Aprilaire 700 Humidifier
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
