Question about Tanita Health & Beauty
Tanita HD-357 bathroom scale has scanty manuel. I can't get it to turn on or get the battery storage on back to open
SOURCE: electronic bathroom scale lithium battery spent
I had a problem changing the battery too. I just couldn't get it out and was afraid of prying too hard because I might break it. So I called customer service to ask them (a bit extreme) but they basically just told me to take a small screwdriver (I used a hair pin) and pop it out. I tried again by pushing down on the opposite side instead of lifting and it popped right out. The battery is just a small electronic one like in a car's keyless entry controller.
Posted on Dec 10, 2008
SOURCE: How do I set Tanita digital scale with 2 memory
Go to www.Tanista.com/ProductManual/PDFs/2001_manual.pdf
This should provide the answers you are looking for.
law4644
Posted on Jan 21, 2009
fitnessbalan
  • 59 Answers
SOURCE: somehow my tanita ultimate scale has been switched
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Posted on Mar 16, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
Our tanita HD351 scale not working
It is possible the replacement batteries are defective, the wrong type, or not installed correctly.
Jul 14, 2016 | Tanita HD 351 High Capacity Bathroom Scale
How to clear memory from a HD 351 Tanita Scale?
leave battery out for a while or look for a pin hole to put a pin in to reset it
Jul 06, 2015 | Tanita Health & Beauty
I have a Tanita Digital Scale with no user manual. Is there a web site where I can download the user manual?
Hi yokoone...
You did not say which model Tanita scale you have, so I will send you to the following webpage and you can download a free user manual for your scale.
Please take time to rate me
http://www.tanita.com/en/digital-scales/
Aug 18, 2011 | Home
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Change settings. model #2202/UM-016 I have lost the directions and can't figure out how to change my persona settings. In an attempt to change my age I changed my *** and can't change it back.
I searched into this site with the same problem, how to update/reprogram the UM 016.
I figured out how to do it, shame there\'s no mention of updating memory data in the Tanita literature.
Assuming scale has batteries and old settings.
Press \'set\' button instead of memory or guest. The \'1\' memory should appear and blink. If you want to reset the \'2\' memory, press up key until the \'2\' appears and blinks, then press \'set\' again.\'
When you press \'set\' while the memory location is blinking, you should be able to page through and change the age/height/sex settings for the scale memories. When you are done, the scale will eventually shut down, saving your new settings, which you access with the \'up\' button when you want to use the scale.
Oct 19, 2010 | Tanita Digital Body Fat Scale with 2...
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Tanita innerscan stopped working. New batteries installed but will not switch on. There is no display except on the guest button which comes up with "88888" when pressed. Any ideas - thanks
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Dec 30, 2009 | Tanita BC-533 InnerScan Body Comp Scale
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
Tanita Scales
Not sure what model you have but here is link to product website of the manufaturer. http://www.tanita.com/en/personal if you click on your manual there is a link to download manual
Mar 23, 2009 | Tanita Digital Body Fat Scale with 2...
Health & Beauty Logo
37 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
