Question about JBL PRX525 Speaker System
Jbl prx 525 speaker replacement - JBL PRX525 Speaker System
4 Suggested Answers
  • 133 Answers
SOURCE: i have a jbl 525 powered speaker but it wont play
Check the incorporated capacitors (if any), also inspect the braid speaker wire on the bass speakers (i understand that these are cutting out).
The braid wires are located between the speaker connection terminal and the speaker cone - if these are damaged or broken, this can cause the speaker to cut out intermittently. To see if this is the case, try to push the speaker membrane gently inward when the speaker cuts out - if it momentarily regains function, then the braid is almost certainly damaged.
Braid wires can be resoldered, but it's not a very easy task because of the structure of the braid, which makes it difficult to clean and solder.
You should have it repaired by someone with good soldering skills or at a speaker repair shop, otherwise the alternative is to replace the speaker.
regards
Triarcuate
Posted on Sep 29, 2009
technical114
  • 1851 Answers
SOURCE: my JBl PRX 515 has
Your speaker is an active one. This means that it has indepented amplifier for low and high frequencies. So maybe the woofer (low speaker) is still active but its amplifier is defective. In order to make things more clear take a look at this block diagram to understand the signal flow:
I suggest you to unscrew the screws at the back panel and eject the whole electronics from the inside:
Take care the cables that connect the electronics with the speakers. If it's easy mark what goes where and unplug these cables. Now with the electronics on the table try to locate fuse(s) that may have been blown; since you don't smell burned components, fuses is the most common problem. Replace any blown fuse with the same one and put things back in the proper order. In case that you don't locate any fuses the problem is at components and I can't be sure if you can manage replacing components.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 13, 2010
SOURCE: Hi, I have 2 JBL
i had to buy a complete amp and replace the old
Posted on Oct 07, 2010
Hi jbl prx525
http://www.jblproservice.com/navigation/PRX-Series.html
This is the exploded view, what seems to be the issue??
Jun 20, 2014 | JBL PRX525 Speaker System
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
Pull the input plate off of the back, there are usually light bulbs in there that act as fuses
Jbl 635 over heating and shutting down in the middle of your gig needs 20 mins before reset ans shuts down again
I had same issue with the series below (525). I removed the amp and there was an aluminum inside cover I took off the amp that was secured by a single top and single bolt/nut combo. This was holding in all the heat but also perhaps to physically dampen potential vibration of some of the components. I got mine to cool down 10c less than one with the manufacturer's case left intact (unaffected speaker) and it quit cutting out on me without having to devise a complex fan. Hopefully this is true for the PRX 600 series as well.
Jun 02, 2012 | JBL PRX635 Speaker PA Active
I have a pair of jbl 512m speakers one is louder than the other one but it works
Make sure your audio interconnecting cables are XLR or TRS balanced lines. Use of TS cables similar to guitar cables with only two conductors (only the tip and the sleeve) reduce the gain 6 DB and contribute to hum and noise.
Sep 03, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
How can I disable the gate in the PRX512M
YOU CANNOT DISABLE THE GATE. TWO SPEAKERS HAVE A PROBLEM WHICH APPEAR AFTER 20 HR USE. THEY WOULD CRACKLE SPORADICALLY AT A LOW LEVEL. THEY HAVE NOW BEEN REPLACED.NO LONGER AVAIBLE FOR USE.
Mar 23, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
JBL PRX525 Speaker System Logo
91 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
