Question about Sierra Print Artist Platinum
How to install graphics grabber catalog from sierra print artist to computer
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: I have Windows XP on my PC and would like to
Explore the Sierra Disney Micky & Friends Print Artist CD and locate and click the setup.exe file.
Posted on Aug 30, 2009
The file I am trying to open from my projects send a message the print artist is not responding, then remains on toshiba screen and will not exit
Sounds like your application is corrupted. Re install it, update it, and try again. Some apps require un-installing before you can re-install, so be aware the installer might ask you to do this. Typically user files are not deleted when re-installing.
Mar 20, 2015 | Sierra Print Artist Platinum
Www novadevelopment com support
Uninstall your current version of Print Artist, and then install it on a different directory. Also, use Run as Administrator when installing Print Artist. Just to be sure, after you installed Print Artist, right-click on it then Run as Administrator to avoid problems with Windows 7.
Apr 02, 2014 | Computers & Internet
How to get free serial number of print artist
Buy a copy of the program and the serial number comes with it for free. If you're trying to pirate the program you'll have to look elsewhere.
Mar 07, 2013 | Sierra Print Artist Gold 4.0
Sierra
Someone please help us. I too have missplaced mine.
I am knjdenby@shaw.ca
Thank You
Feb 13, 2013 | Sierra Print Artist Platinum Version 4.5...
With a Windows 7 operating system, what product can I find that would be comparable to the old Print Artist 8 Grande Suite? Has Nova come up with anything to compare (I've gotten more recent versions and...
Hi Joni703:
I would recomend running your old Print Artist 8 in compatability mode, since you are dissatisfied with the new programs. to do so, install the program on your windows 7 system, if you have not tried already, and right-click on the corresponding desktop shortcut. When a menu comes up, left-click on properties. at the top of the properties window, click on the compatability tab. Next, click on the check box labeled "run this program in compatability mode for:" and pick the system you have used Sierra Print Artist Platinum on previously. It should function normally.
Jan 12, 2011 | Sierra Print Artist Platinum
New computer running Windows 7. Print Master Platinum will not open. Is there a fix? Ran fine with XP.
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and select the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website.
Jan 06, 2011 | Sierra Print Artist Platinum
Had to redo computer and reinstall. PA 4. won't install.
I found a solution for installing Sierra Print Artist 4 on XP at this site
http://forum.oldversion.com/programs-support/5831-printartist-4-a.html I did it, works great!
Posting below, thanks to izzy_eckerslike :
"""There is a way to force your computer to load print artist 4
Click on display /settings & reduce colour quality to 16 bit & reduce your screen resolution to 800X600
Then insert the Printartist disk & select install, as before you will see the Sierra logo on your taskbar but it won't move or do anything.
Now put your screen settings back the way they were before & you should see the install screen jump off the taskbar so you can access it.
It will test your computer & tell you it fails as it can't recognise newer technology but ignore that & select 'install anyway' & all should be working"""
Jun 30, 2009 | Sierra Print Artist Platinum
Sierra Print Artist Platinum  Logo
61 people viewed this question
Top Sierra Computers & Internet Experts
Glenn
Glenn
Jacqueline
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
