I am getting a fault code H E flashing intermittantly and a constant loud clicking noise when it does decide to run
SOURCE: Hi I have a ideal isar 30100 combi boiler which
jumper links not inserted in to pcb is h5 code
Testimonial: "Hi mylandlord eventually sussed it out and blanked of port1 and 3 on the pcb thanks for your help T"
SOURCE: ideal isar 30 he making noise when going too low
. is the flame detection probe or its wiring harness, this sits right on the heat ex and over time melts and sticks to the heat ex so looses continuty.
To check if the detection probes faulty, get a multimeter pull the wiring off the probe stick one end of multimeter on probe connection, other end to the wiring plug, set your multimeter to mirco volts. fire boiler up. you want more than 1.5MV's or probes is knakered! Check continuity of wiring, also check wiring is full pushed in to the white molex connector too.
SOURCE: boiler keeps blowing fuses in pcb ideal isar he
The model # you listed is for a vent-free, natural gas, space heater and requires no electricity to operate. Unless, you have the optional blower. If the blower accessory is what's blowing the fuses, there is a short in wiring to the blower motor. Other than that, there is nothing else about this heater, that would be blowing fuses.
Is the above, the problem you're having? If so, unplug the blower from the wall outlet, until it can be repaired or replaced. The heater will continue to operate and heat with out the blower.
For more information about your heater, go to the link below.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107882-01.pdf
