Question about Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma Printer
My printer doesn't want to take the paper properly. It only takes the right side and makes a paper jam. I have no clue what to do. i need help NOW!
    Genius:
  • 2,985 Answers
Unload all paper. Examine the feed track for any obstruction- paper fragment - cookie crumbs. Take a vacuum nozzle to it and give it a good suck out. Now feed a heavy weight paper/thin card through. Did it do the trick?
Posted on May 23, 2007
2 Suggested Answers
SOURCE: canon pixma ip1200
download free installer of canon pixma ip1200
Posted on Dec 06, 2007
Canon Pixma MP160 doesn't take papers, looks like paper jam, but no paper jam in it. please how can I fix it.
take the printer and put it up side down, if you are lucky the object that bloks the paper acces will fall. if it will not fall you will have to take the printer to a tech.
Nov 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My Canon ip2600 keeps getting jammed. It takes
Lol!!! I was having the same exact problem--- looked in it, didn't see a thing, opened it, still didn't see a thing! I turned it over-- and sure enough, a pen fell out!! lol
Jul 21, 2010 | Canon Pixma iP2600 Photo InkJet Printer
I continue to get error message 3 from my pixma
E3 is paper jam.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service, because in most case when have a paper jam it's under withe rollers and printer must be disassembled.
Nov 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jams on right side of printer
hi,
paper feed assembly allignment problem.
pls contact to any printer specialist for allignment.
Aug 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA iP1500 InkJet Photo Printer Logo
105 people viewed this question
old marine
old marine
