Question about Hoover Dryers
Hoover DYC9913AX The heat seems to be out of order after 6 month the spin is alright but no heat so no drying and no water fills up in the door as it should.
Gentlmen you need to move with the times this tumble dryer has no element it is whats caled a heatpump solution ,there is no exhaust for the air to go out of as it is a sealed enviroment the air re-circulates within the machine
Posted on Jan 26, 2014
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Water not heating or drying
It is possible that the element has gone, \even after such a short period of time.
If it is only 6 months old, then you need to contact Hotpoint service department, and get it fixed under the guarantee, do not try to fix it yourself,, as you could invalidate the guarantee.
If you look inside your user instruction hand book you will find the telephone number you need to ring to get service.
Please rate my fixya solution.
Thankyou.
Posted on Feb 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: Dryer seems to heat up but clothes not drying
check for clogged passages from where the door opens to the exhaust hose. start ate the exhaust and work backwards.
Posted on Jan 30, 2009
  • 3074 Answers
SOURCE: just installed dryer heating element,loudsqueeking
did you use WD-40 on the motor, if you do you will need to unplug the dryer, and with a small drill bit drill a hole until you hit the cotton(yellow stuff) then with the straw on the WD-40 dampen the cotton cover hole with tape, unless on your motor there is an oil plug. the other things may be: drum rollers. drum glides, drum belt, and possible the idler arm. Hope this helps Tim
Posted on Apr 16, 2011
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
My washer seems to be stuck on a boil wash i turn the knob to another setting and the time light flashers but will not stay on and the washer start a boil wash
Possibly the water level sensor inside is out of order. So, the program only gives the command for filling with water and heating.
Sep 10, 2017 | Hoover Nextra HNT 2135 Top Load Washer
Flashing programme lights
Hi
Thanks for using FixYa. That means the control sensed that the heater in the D/W did not operate 3 times in a row. So the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. Use a meter to see if it reads open; if so orders a heater assay it will come with a new control replace it too. If heater checks good then press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec and all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water and incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this ensures your unit fills with hot water and not cold
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Dishwashers
Blocked filters/dodgy pump?
The problem you are having could simply be the inlet valve.
The inlet hose is attached to the inlet valve on the machine. Where it screws on that is.
You can get a valve from an appliance parts shop and they are inexpensive.
Jun 18, 2009 | Hoover HTC243 Top Load Washer
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dryers Logo
167 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
