Question about Hitachi Televison & Video
Blue blob on screen
Recently I replaced the lamp on my (3) year old 52". After a mon6th or so a blue blob started to appear alomost centrer of the screen. What would cause such thing and will it be expensive to repair.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    its problem of light engine and would be costly repair.
    Blue LCD and UV filter will be replaced in light engine (if TV tech can do that) or complete light engine replacement.
Took the TV to the shop...there I learned that the obtical engine assambly has been a pain on this type of TV. The repairer suggested on calling the company and to compliant about it, since there seems to be a known problem with that assambly. The company will send the part ($900.00 cost) to the shop and all I have to pay is for the remove and instalation of the assambly.
Posted on Jan 06, 2009
Replace lamp notice appearing on screen. The only noticeable imperfection on screen is very slight blue tinge on left hand side. Is this common can i purchase lamp and replace it myself or is an expensive...
You can purchase the lamp yourself and replace it yourself. The lamp is built to fail after about 3-5 years depending on how often you watch it. There are step by step directions in your user's manual. If you have lost or misplaced it, you can download it for free in PDF format on the LG website. The lamp usually are around $200.
Oct 05, 2009 | LG RU-52SZ30 52" Rear Projection...
Replaced bulb - no picture - blue dim light
Ur CRT need a rejuvenation,it a messy job.
It cost u the big screen repair shop about $300 dallors.
Sep 02, 2009 | Televison & Video
Hitachi dlp - 52" . neon blobs
Hi, the convergence chips on the board are showing signs of failure. simply replacing the board will fix this issue.(convergence board failure)
May 14, 2009 | Hitachi Televison & Video
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue streak at bottem of screen
You have the classic "blue blobs," In most of Sony's rear projection LCD's, the Optical block is bad. Manufacturer's defect. The blue panel inside of the optical block starts de-laminating (due to heat from the lamp). This is a very common problem. I have changed about 70-80 optical blocks myself over the course of about 4 years.
There is no other fix but to replace the optical block. Unfortunately, it will get worse, and will probably develop "stars," or stuck pixels, as well. You can call Sony and try to get some assistance, but the extended warranty on these sets has recently expired.
Hope this helps you in some way...
Jan 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue blob
Hello rivas_gab. Before I answeryour question let me explain a little how your tv works. You TV uses is a 3LCDtv that gets its picture from a lamp, the lamp produces a white light brighterthan the sun, the light goes through a square prism and is split 3 ways, eachgoing through a small LCD chip (blue, red & green). Then it travels troughthe light engine where the final picture is produced. The blue blobthat appears on the screen might be caused by one or two lcd chips that havestarted to get burn by the intense heat emitted from the light of the lamp. If that is theproblem you’ll have to replace the entire light engine, the other option isthat you buy the prism with the lcd chips, how ever that almost impossible becausenobody that I know sells them separately. If you decide tobuy, search buy part number, NOT model number, otherwise you’ll run the risk ofgetting non compatible parts. If you’re lookinga place to purchase look for dedicated tv part distributors (my personal recommendation:Discount-Merchant ). Happyhunting.
Dec 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Changing the lamp on a DLP LCD tv
Most definitely! The lamp is a consumer replaceable item and your owners manual should have instructions on how to complete this task. If you don't have your owners manual and more post your model number and i will get you some instructions on how to replace it!
Tim Nolan
Sep 24, 2008 | Televison & Video
Sony 3LCD rear projection ghosting
sorry to inform you my friend but a lamp wont fix your problem. i afraid you will need an optical assy. this part is fairly expensive
Sep 29, 2007 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
