Question about HP Pavilion dv7-1130us laptop
The fan so noise and can't cool - HP Pavilion dv7-1130us laptop
  • HP Master
  • 2,878 Answers
Use canned air to blow out dust. It really helps.
Posted on Nov 08, 2012
New Cooling Fan is Very Loud
might be a fan with a faulty bearing lubricate it by pulling the sticker off and the cover then use some oil NOT WD40 if this doesnt work then get another fan
Dec 08, 2012 | Compaq Presario CQ56110US Laptop
My notebook fan so noise and can't cool
I agree with joe, clean fan, vents, fins, etc. Avoid using a laptop on a soft surface that restrict air flow. Improve/ increase ventilation and air flow , if necessary use a Laptop Cooler.
Nov 08, 2012 | Computers & Internet
AC and Cooling Fans Not Working
Try installing a jumper across the N/O terminal at the relay socket. Temp sensor in the radiator or in the thermostat housing supplies the signal for the relay the other relay signal is supplied by A/C in on position. both fans will run continuous with A/C on. One fan runs intermittent relative to water temp. Be careful not to blow a head gasket. If you leave the jumpers in place, the fans will stop when the ignition is turned off, save the engine until you isolate the relay signal problem. then simply remove jumpers and reinstall the relays
Feb 28, 2017 | 1989 Toyota Camry
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
2003 Nissan Xterra - Fan noise when a/c on
No that doesn't sound like the problem, the fan clutch locks up to cool the engine off due to the increased load of the AC system on the cooling system, so it locks up and gets much louder. If it didn't lock up the engine would overheat.
Jun 28, 2012 | Cars & Trucks
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
Iam using HP Desktop D530 when i open some programmes but processor fan runs so fast and loud 2 gb ram in my pc and hard disk is 20 gb how can i reduce noice of fan ?
To reduce the fan noise, open the PC Case and clean the fan. Also, proper ventilation keeps the system cool and the fan runs at lower speed.
Hope this helps!
CreativeTECH
Dec 11, 2010 | HP Compaq d530 Small Form Factor PC...
My desktop will not come on it was coming on but it was loud then i turned it off and now it wont come on
The typical desktop has at least 2 fans. 1 on the processor & 1 inside the power supply.
It sounds like a cooling fan was making noise ,not cooling properly and then something heated & failed. Unplug it for a while then try it again if it works again but is quiet I would turn it off fast. That means the fan quit all together and will burn up. If it does start up again and is still noisy I still would not run it. Find out the source of the noise before it fails for good.
SEE THE FANS ON EACH Power supply on left / Processor fan & heat-sink on right
Oct 11, 2010 | Computers & Internet
Loud noise under refrigerator
it's a condenser fan, it's located on the bottom ,,at the back of the frig
unplug it first from the wall, & vaccum under neath bottom & around the fan,,then you need to see if the fan came loose from the shaft & if so tighten & also make sure nothing is caught in the fan...
Aug 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Seems to be a noisy fan on mb4210 combo
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Apr 18, 2009 | Marshall Music
HP Pavilion dv7-1130us laptop Logo
12 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
