Question about Belkin (F5D7230-4) Router (587009)
Belkin Router not allowing an Internet connection
I'm using a cable modem and it used to be plugged into my wirless router, then I had an ethernet cable running from the router into my PC's (I have 2 connected via cables, laptop via wireless). Now my router is not letting me connect to the internet on either PC, but it seems my home network is still running. The "connected" light just flashes when I think it should be on constantly and the WLAN light flickers like it should do. I've looked at everything on the setup menu and can't see anythings changed, in the internet status it says "not connected", I've even restored factory defaults and it's still not working. The only way I can get online is to plug my modem directly into one of my computers.
Anyone got any idea's as to why it's not working?
  • 2 more comments
  • npeters1868 Jan 07, 2009
  • arunsant Jan 10, 2009
    I'm having the same problem. I got a cable modem from time warner and I am able to connect if I hardwire my computer to the cable modem. If I try to connect wirelessly via the belkin router, I'm not able to connect to the internet. The "WAN" light is on but the"Connected" light on the router is blinking.
    Got this from the manual:
    Solution:
    If you cannot connect to the Internet, the “WAN” light is on, and the “Connected” light is blinking, the problem may be that your connection type may not match the ISP’s connection.
    • If you have a “static IP address” connection, your ISP must assign you the IP address, subnet mask, and gateway address. Please refer to the section entitled “Alternate Setup Method” for details on changing this setting.
    • If you have a “PPPoE” connection, your ISP will assign you a user name and password and sometimes a service name. Make sure the Router connection type is configured to PPPoE and the settings are entered properly. Please refer to your Router’s User Guide section entitled “Alternate Setup Method” for details on changing this setting.
    112 Troubleshooting
    • You may need to configure your Router to meet the specific requirements of your ISP. To search our Knowledge Base for
    ISP-specific issues, go to:http://web.belkin.com/support and type in “ISP”
    If you are still unable to access the Internet after verifying these settings, please contact Belkin Technical Support.
  • gh1980 Jan 10, 2009
    It worked!! Thanks a lot arunsant :)
  • Belkin Care
    Belkin Care Dec 15, 2016
    Contact Belkin for Care at 1-800-585-2494 Toll Free
  • 585 Answers
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Posted on Jan 06, 2009
5 Suggested Answers
marked
  • 6487 Answers
SOURCE: Status and WLAN lights
First thing to do here is to reset the router, to reset it Press and hold the reset button for 15 seconds while the power is ON then fater that just again the setup of the router to your computer to reconfifgure it back and hopefully everything will be back to normal....
Posted on Nov 10, 2008
raffaiel
  • 209 Answers
SOURCE: wlan lights off and now wirless access
Does your computer say Network cable unplugged?
If the wlan light is off, it means that your computer is not being detected by your router. You can try unplugging and replugging the ethernet cable at the back of the computer. Make sure that you hear a 'click' when you plug it back in to make sure tha it is properly seated. Check also the light on the wan port (desktops usually have lights..not sure about laptops though).
Do the same process with the ethernet cable but now from the other end--the one connected to the modem/router. if your modem/router have other ports on it, try to connect it to other ports as well. If you're wan light is still off, try using a different ethernet cable.
what's wrong with your wireless access? i can't read it from the title.
Posted on May 04, 2009
marked
  • 6487 Answers
SOURCE: PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Posted on Oct 17, 2009
Testimonial: "it certainly seems faster, even for the wireless machine. Thanks!!!"
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
My netgear wireless-N 300 modem router dgn2200
IF YOU WANT TO USE NETGEAR AS A ROUTER YOU PLUG THE ETH-CABLE TO IT AND START LOOK IN THE PC FOR WIRELESS NETWORK.ON THE OTHER YOU CAN CONNECT YOU DSL CABLE DIRECTLY TO YOUR PC.
Apr 11, 2012 | NetGear Computers & Internet
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I cant connect to the internet
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
I have a wireless router i can get it working right?
How to quickly install and use your wireless router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 26, 2010 | Airlink AR430W Wireless Router
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Belkin (F5D7230-4) Router (587009) Logo
7,310 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
