Question about HP PSC 2175 All-In-One InkJet Printer
How do I clean the underside of the glass?
I need desperately to clean the underside of the glass platen on tis printer but am unable to figure our how to get to it. Can anyone please help? Thanks!
  • anne0 Jan 12, 2009
    same problem - thanks for any help.
    President:
  • 2,692 Answers
Posted on Jan 18, 2009
Scanner window is cloudy on bottom. needs to be wiped clean
if you are a technical kind of guy you may want to download the service manual from MAISE MANUALS to see the correct proceedure to remove the platen glass without damaging your scanner!
attempting to do this without good instruction will most definatley be a bad day for your printer this job would likely take me about 3/4hr to complete as to remove the glass several covers need removing.
Jan 14, 2014 | HP Photosmart C6180 All-In-One InkJet...
How to get inside the scanner head chamber to clean the underside of the glass platen? Or just get at the underside of the glass, it's not a sealed chamber and has become totally obscured by a surface...
I clicked on this by mistake but this sounds like a call to Canon support would do the most good.Here is the number Contact Us at 1-800-OKCANON Hope this helps.
May 10, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How do I remove the glass from my HP 3210 all-in-one printer? I need to clean the underside of the glass. Thanks
Remove the 2 #10 torx screws which are in front of the glass area. Remove the platen cover by lifting it straight up (after opening it) and pressing in on the two spots marked on the hinge. The platen cover can now be lifted out of its hinge slots. Unplug the wire which powers the platen cover light and set the cover aside. Now remove the three additional #10 torx screws along the rear of the machine. The whole top including the glass can now be lifter up and off the machine. Clean the glass with a good glass cleaner and a soft cloth or lens paper. Make sure there is no lint on the glass and reverse the order to reassemble it.
Nov 28, 2010 | HP Photosmart 3210 All-In-One InkJet...
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
May 08, 2010 | Ricoh Aficio 2232C Color Copier
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Head unit wont scan
Clean the underside of the platen glass, be careful to remove the screws, also there is a plastic cover at the top of the platen under it there is a white correction plate clean this plate with cloth.
Feb 06, 2009 | Sharp AL 1631 Copier
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
White spots on scanned photos
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Apr 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How to clean underside of platen?
The underside of the scanner glass can only be reached by a a canon service tech. The compartment is supposed to be sealed and dust-free, so if it has gotten dirty, you should send the unit back to Canon for servicing.
Feb 07, 2008 | Canon imageCLASS D320 All-In-One Laser...
HP PSC 2175 All-In-One InkJet Printer Logo
305 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
