Question about Grilling
NG conversion kit for a Security fireplace model PDV38, Serial # 000564
  • 1314 Answers
SOURCE: Converting a Cabana Kitchens CNA 480 from NG to LP
go back to place of purchase they will have a kit
Posted on Dec 31, 2007
SOURCE: Conversion kit or fix for LP to NG for the Char-Griller
I removed the jets and drilled them out, #54 is what I started with and then moved up from there to get a good flame( gas pressure may be diffrent in your area). I went to lowes and purchased the universal gas line for grills. Item #: 206469 from lowes, I removed the hoses from the valves, and proceeded to remove the regulator from the hose. After that, i used a 1/4" npt coupling, and a 1/4/" NPT to 3/8" Flare fitting( fits to hose). I drilled a hole in the brace that is under the clamshell(it says UP) that way I had a place to relive stress from the hoses. I threaded the Coupler to the Y then threaded the Flare fitting thru the sheet metal and then the coupling. This was an easy mod minus the garage in disarray, my precision calipers on loan, and 3 trips to the hardware store. The connection that goes to the house is a 3/8" NPT Female, my house has 1/2" pipe, The one wasted trip to the store is because i didnt bring the fitting with me to the store and assumed the size was 1/2 to 3/4(Rookie Mistake). 46e03a6.jpg846ce6e.jpgb1bb7d1.jpg
It was 35 degrees when I finished this mod, and on high for all 3 burners, I got it to 675F in a hurry. the needle was still creepin up, but that is when I said that was good enough for me.
I used my lathe to drill out the jets, ksware is correct with how easy the jets break. I broke the one in the side burner. I will make another one when I get an hour or two. Good luck to you and happy grilling.
Little Elm, Tx.
Posted on Jan 03, 2010
  • 512 Answers
SOURCE: where can i find conversion kit for weber platinum
Weber does not sell conversion kits. They sell either lp or ng grills. They say the liability is to high to have someone convert grill. No parts available have to buy new grill.
Posted on Mar 26, 2010
SOURCE: I'm trying to convert to
Tne 720-0677 that I purchased came with a NG conversion kit and has all the pieces needed. Try here and maybe this will help
http://www.shopnexgrill.com/category/nexgrill
Posted on Aug 22, 2010
  • 4736 Answers
SOURCE: How can I find a
I believe the Lowe's salesperson may have misled you. I may be wrong, but the find at for sure contact Fiesta Grill in the USA at 800-396-3838. In Canada 800-387-8643.
Posted on Mar 22, 2011
I need to convert from gas to propane and I need a owners manual
Which model of range do you have? Maytag has owner's manuals for many of their appliances here: https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . Enter the model number and click Search. Most ranges will have the serial number on a plaque below the display, on the frame of the oven (behind the oven door), on the frame of the storage drawer (visible when the drawer is open) or near the legs of the unit.
Often the conversion kit is sold with the range and is attached to the back of the range near the regulator. The instructions are in the kit. (Note this should be done by a professional. Your propane company may have a person available to do the conversion.) If the conversion kit is not supplied with the range, you should be able to order it from the manufacturer. (Some manufacturers will only ship the kit to the service person who will do the swap.)
Please add a comment with your model of range for additional information. (There are some manufacturers who do not supply conversion kits and you must order the correct range from the factory.)
The conversion is usually straight forward. Swap the regulator from NG to LP by turning over the part (it's labeled clearly) in the regulator. Using a small nut driver, swap the orifices for the cooktop. Do one at a time and check the labels. (My range conversion kit has a different set of letters on the NG orifices (A-G) and the LP orifices (L-R). Others use different colors for each orifice.) Then open the oven and swap the broiler orifice and the bake orifice. Rotate the air flow valve appropriately.
I hope this helps.
Sep 02, 2011 | Maytag Kitchen Ranges
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
Is there a conversion kit for Jenn-Air Model No: 720-0061-LP to convert from LP to Natural Gas?
Matt, I am not aware of one. Nor, whether it's approved or not, by the manufacturer, Nexgril.
My best advice is to contact their Customer Support Dept @ 800-913-8999
Keep in mind, it you are able to convert it, the gill will no longer get as hot as it does with propane.
Propane burns hotter than Natural Gas in an outdoor environment.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Jul 28, 2011 | Grilling
I bought a converson package for NG that included the regulator and a new set of burners. I'm getting very little gas. I can smell the gas but not light a flame
If the conversion kit came with new NG orifices, you need to install them as the LP orifices are to small to use with NG and all you will get is a very small flame, if any at all. If the NG conversion kit did not come with new NG orifices, then you will have to order some.
Jun 13, 2011 | Frigidaire FD30HONGDC (NG) Grill
I have a Weber Silver B grill that I purchased 12 years ago.I would like to convert it from propane to Natural Gas. I have been told I cant! Is this true? If not, where can I get a conversion kit? Thanks!
Weber stopped selling conversion kits due to some legal action in 2008. There are no longer kits available. What you would have to do to covert it is order a replacement gas valve for the NG version of your grill just to get the orifices. Then you have to replace the LP regulator with a NG regulator. Typically most NG grills do NOT have a regulator but local building codes will require a NG regulator and a different gas line hose.
Conversion of a BBQ gas valve to NG is a matter of drilling out the orifice to a larger hole in an LP orifice.
You will not find anyone that will perform this conversion for you due to legal liabilites.
If you want to convert it... you will either have to order the whole gas control valve for NG or drill out the orifices yourself in your current gas valve hoping your got the orifice hole size correct when you drilled it. Mind you all liability for doing this lies solely with you.
This site has all weber parts:
http://www.clagrills.com/allgrillparts/weber/weber-models.htm
http://www.clagrills.com/gasgrillparts/weber/weber-gas-grill-parts-home.htm
Thanks for choosing FixYa,
Kelly
Apr 29, 2011 | Weber Genesis Silver B Grill
Is there a conversion kit from lp to natural gas for this model VM450SSP
Usually there are no conversions for LPG - NG on BBQ units. You need to contact the manufacturer about this and then get a 'Gas Safe' engineer to carry out the conversion.
The reason for this is that LPG is a higher pressure (37mb) than NG (20mb), and stringent testing must be carried out for leaks etc.
I hope this helps
Jul 07, 2009 | Vermont American Tool Company VM450SSP...
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
Conversion kit
Yes,
If you have the Model and serial Number. I can look up that information for you.
Fireplace-girl
Apr 14, 2008 | Heating & Cooling
Grilling Logo
67 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
