Question about HP LaserJet 4050 Printer
How to turn off FTP on HP LaserJet 4050
How can I turn off FTP on HP LaserJet 4050
leroyal
  • 2120 Answers
SOURCE: HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Posted on Jan 05, 2009
POCBM
  • 121 Answers
SOURCE: separation pad for HP LaserJet 4050
Open tray 1
remove the pick up roller
pad is located under the roller
in the front center of the pad is a small notch
inset a small screwdriver or key something small and flat.
give it a twist and the pad should pop out.
install the new pad by aligning with the holes and push down should sort of snap into place.
Reinstall pick up roller
Hope this helps
Posted on Apr 25, 2009
  • 217 Answers
SOURCE: HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Posted on Apr 05, 2010
tballone
  • 126 Answers
SOURCE: Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Posted on Oct 20, 2010
seeker5211
  • 1089 Answers
SOURCE: pcl xl error subsystem kernel,
First thing to do is reload the drivers from hp.com. Sounds like the PCL drivers are hosed.
Posted on Sep 03, 2011
Oct 20, 2010 | HP LaserJet 4050 Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
I have a 50.2 fuser error. What does that mean
Loose fuser tabs on the HP LaserJet 4000/4050/4100 - a potential 50.2 error If you experience a "50.2" fuser error while using a LaserJet 4000, 4050, or 4100 fuser, you should check to see if two tabs on the fuser have come loose. (They can get dislodged during shipping or during istallation.)
Turn your printer off and remove your fuser. Flip it to the gear side (the left side) and press inwards on the fuser tab to make sure it is fully clicked in place, as shown below.
Then flip the fuser over to the right side (the non-gear side) and press in on the other fuser tab to make sure it is also fully clicked in place.
(right side of a LaserJet 4000/4050 fuser pictured below)
Mar 31, 2010 | HP LaserJet 4200 Printer
Feb 19, 2010 | HP LaserJet 4050 Printer
I have a hp laserjet 4050 that will print my files but will reverse and print same files again. what is the problem?
Check your driver settings. Make sure the number of copies is set at 1 copie.
Gerrit Jan
Nov 01, 2009 | HP LaserJet 4050 Printer
How do I download a drive for my laserjet 4050? I
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=18322&prodTypeId=18972&prodSeriesId=25475&swLang=8&taskId=135&swEnvOID=228
Aug 23, 2009 | HP LaserJet 4050 Printer
Separation pad for HP LaserJet 4050
Open tray 1
Hope this helps
Mar 25, 2009 | HP LaserJet 4050 Printer
turn off
turn off
turn on
Jan 05, 2009 | HP LaserJet 4050 Printer
How to change cartridge
If it is remanufactured, it is probably bad. Move the drum cover back, there should be no toner on the drum.
Dec 19, 2008 | HP LaserJet 4050 Printer
SCANNER
You need to download and install software first.
Here is the link, you just need to copy and paste the link below on internetexplorer bar :
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Oct 20, 2007 | HP ScanJet 3200C Flatbed Scanner
HP LaserJet 4050 Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
