Question about Dehumidifiers
Dehumidifier model DH10 Air-Dri
It works afew moments then starts juddering sometimes red light comes on sometimes not,we dont know how to get the outer casing off
2 Suggested Answers
  • 117 Answers
SOURCE: light comes on but dehumidifier does not work
Is it running?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less. In that case your unit won't turn on.
Posted on Jan 05, 2010
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
My DEHUMIDIFIER shows check-red light
well you didnt mention model but most times this occurs on dehumidifyers it means the bucket full sensor has tripped , this does not mean that bucket is full, it just means that bucket is either not seated all the way in or maybe the sensor has moved in the bucket and no longer hits the sensor as it should , try reposisioning the bucket and full sensor , ck for looseness
Nov 15, 2014 | Dehumidifiers
Why is my ebacnot working blue light comes on then goes of and red light comes on why
the units self testing and it takes a moment to ck that everything is ok , red light ind. it;s found a problem , ck simple things first , empty bucket, ck float sensor inside bucket ck for Level (gravity) ck filter for cleaning and reset filter alarm if present , then move on to more difficult things like is something wrong with cooling fan or did water get inside and dammage something
Oct 10, 2014 | Dehumidifiers
Why is my dri-eaz drizair 1200 dehumidifier freezing over?
There are two major causes of a dehumidifier or air conditioner to freeze up the evaporator coil. First is lack of air flow try cleaning or replacing the air filter if it has one; make sure the fan is running and the coils are clean. Second is a low charge of refrigerant requiring a refrigerant leak check; repair and recharge. A slight overcharge will keep a dehumidifier from freezing in cooler ambient temperatures.
Sep 25, 2014 | Dehumidifiers
I have a Silhouette dehumidifier model # DDR583R which is about 2-3 yr old. The red light indicating a full tank is on and no water is collected. When I checked the sensor & manually pushed it the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 26, 2010 | Danby DDR583R Dehumidifier
My dehumidifier is not working properly. I do not know how it works, I do not have the manual. I have a temperaturesetting and a humidity level area. Do I need to set it on the humidity level to pull water...
Yes set unit humidity dial about half way or until it comes on. You need something to measure humidity. most of dials dont have a humidity reading. Set at about 50% Rus
Jun 14, 2009 | Maytag M7DH45B2A Dehumidifier
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Sep 17, 2008 | Dehumidifiers
Compressor is not working
Try gently tapping the compressor a few times -use a wooden stick or similar to avoid damage -sometimes that is all that's needed. There are however many other possible reasons for a compressor not to start - most have their own fuse/controller assembly (sometimes this is very obvious inside the case, often a car spade type fuse which is worth checking visually), and there are cut-outs that will stop the compressor if it is low on gas, although usually it will start first for a few seconds if this is the case. Sorry, but the (www.maytagair.com) website is down at the moment, but try it again later and you should find their troubleshooting and support is good. Hope this helps :)
Mar 03, 2007 | Maytag M3DH30B2A Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
