Question about Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230
Motor buzzes loudly and will not start. Breaker will not trip. What could this be caused by? Capacitor tested ok.
  • 5,245 Answers
My pool man stated my pump clogged and tripping the breaker. After trouble shooting we find its the motor we tested at different sources and find the same issue the breaker trips. Is the capacitor
Might be but unlikely I would have thought if the rcd is tripping. That would indicate a current leak to ground which is very unlikely to be caused by a dodgy capacitor..
If the mcb is tripping immediately it indicates a large overload such as might be caused by shorted turns in the motor windings (or bad wiring).
The mcb might trip after a short time with a faulty capacitor - the usual sign the capacitor has failed is a humming noise and the motor turning very slowly or not at all, usually the latter.
There are some variables depending whether the capacitor is just a start capacitor or a combination start and run type.
Jun 29, 2016 | Pool & Spa
Why does my Jobsmart TA-25100VB just buzz and trip the breaker?
A buzzing followed by a breaker tripping shortly after usually indicates a siezed or shorted blower motor or its capacitor faulty if on indoor section, If from outdoor section could be fan motor or its cap bad, compressor or its start components faulty.
Apr 23, 2014 | Heating & Cooling
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
Motor is noisy (loud buzzing). Drum belt seized.
the problem, is with a component,called a capacitor.a capacitor gives a"jump start"to the motor.when this charge or jump start cannot be given,the motor will "hum" or"buzz".a new capacitor should not too expensive.
Oct 16, 2009 | Tricity Bendix TM310W Electric Dryer
PUMP TRIPS BREAKER, BUT SHAFT ROTATES FREELY
Probably not. Take the capacitor off and inspect it for physical damage and if it looks ok take it to an electric motor shop for testing. Assuming it is ok your motor will probably need work or replacement.
Jul 12, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
USQ1102 pump gets power, buzzes, trips breaker
The motor-start capacitor is bad. This is a very common problem. It can be easily and cheaply fixed by replacing the capacitor. Replacements are usually less than $10.
See http://www.youtube.com/watch?v=ZEIv5ClLqXg for a step=by=step guide.
When you have the capacitor in hand, check the model# which is printed on it. Alternatively, you can Google the motor brand & model to find the parts list which will identify the right one. Then Google the part number, to find a seller.
Jun 27, 2009 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Reverse cycle window wall air conditioner. I turn the power on and it is OK when I turn the air conditioner on either manually or with the remote it turns off and trips the main switch. I have tried the...
Tripping the circuit breaker means that something is shorted out. A fan motor or the compressor, most likely. Disconnect the compressor or turn the thermostat up so high the compressor doesn't start. If the breaker still trips, the fan motor or its capacitor are the problem. If the breaker stays on, the compressor or its capacitor are causing the problem.
Jul 26, 2008 | Electrolux Heating & Cooling
Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230 Logo
117 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
