Question about Delta 2572-272 Chrome Coventry Centerset Bathroom Faucet
How to remove stripped hex screw on my delta handle sink faucet?
I tried to drill it and used a #1 screw extractor but won't make it. I think the extractor is too thivk for the hole.
broii4x4
  • 13 Answers
SOURCE: Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Posted on Mar 24, 2009
  • 659 Answers
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Posted on Apr 06, 2009
  • 21 Answers
SOURCE: I do not know how to remove the spout from a Delta
You shouldn't have to remove the ball to take the spout off. It simply slides onto the post. Simply rotate it back and forth while raising it up, it should slide off directly towards the ceiling.
Posted on Nov 16, 2009
motor1258
  • 6674 Answers
SOURCE: My Delta Faucet Leaks
Check that we were looking at same parts diagram, but I would say RP-70 Ball assy., as well as RP-4993 Seats & springs . If it's only dripping, just seats and spring will usually get you by, but if they are sending parts, free of charge, or ball assy., isn't too expensive, I'd change it too. I have had some luck with removing ball assy, cleaning it well with fine steel wool, then removing seals, and springs, stretching spring slightly, to add more pressure to seal, clean seal, then dab on a little vaseline to seals, and re-assemble.
Posted on Jan 07, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: How do you remove a cap from a delta 522 faucet
Sorry to read about your problem, I hope this helps you out.
their is a round top part of the handle, take a knife and pry off the cap, then you will need a Phillips
screw driver
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
I have a Moen 7730 single handle kitchen faucet. There is a slow drip from the end of the spout. I was going to replace the cartridge but I have stripped the hex screw under the handle (it was corro
drill and an easy out . BUT you might want to rethink your problem if you do . and just replace the entire faucet .should have used a good penetrating oil on it before you ruined the set screw .
Jan 02, 2018 | Plumbing
Delta faucets troubleshooting
Spray with lubricant and let it work - you may have to spray more than
once - main thing is do not strip the screw head....try a long handled
screw driver.
Regards,
Dennis
Aug 17, 2014 | Delta Faucet Delta 474-WH Waterfall Single...
How to get a stripped hex 1/8 screw from a Delta Faucet shower handle?
drill it out call delta 1-800-345-delta for new handle
May 29, 2012 | Delta Home
Can't get the handle off the faucet hex won't budge
Don't even bother. I have 3 Delta shower faucets and have run into the same issue WITH ALL 3 .
Step 1: Call Delta and have them send you replacement parts before you follow the next step (Trim sleeve, cartridge, handle)
Step 2: HACKSAW just outside the handle, right through until it snaps off.
That's the only way you will be able to access the nut.
I tried eveything - Vinegar, WD40, CLR, Banging, Jiggling...
Problem: The brass nipple on the cartridge will fuse with the metal on the handle. Alternately, so does the Allen Key screw. They will not release no matter how hard you try.
I called Delta and they confirmed that the two metals will fuse together over time (a short period of time, in my case), but it's not a fault design but the water. Their solution (moving forward) is to wrap the brass nipple with Teflon Tape before attaching the handle, so that the 2 metals won't make contact.
However, one would think that Delta would rectify this issue. Say by enclosing a thin plastic cap that seats over the brass nipple, or better yet, pre-coat the inside of the handle themselves?
Regardless, don't expend too much energy. If you can't loosen anything,
HACKSAW RIGHT THROUGH THE TRIM SLEEVE AND BRASS NIPPLE OF THE CARTRIDGE and snap it off to access the cartridge nut.
Apr 01, 2012 | Delta & Single Handle Shower Faucet
On my delta shower handle 1400 series i know my set screw is stripped and i can not get it off i really jus wanna break it off and buy a whole new one can someone help me out before i go crazy on the...
You can use any high speed drill bit and drill the set screw out, it should be chrome plated brass, so, it will be soft. If you get your sizing right, maybe, just over the size of hex in set screw, you may be able to save the handle and get the rest of the set screw out. You could also try an "easy out" that will fit in the shole you drill to extract the set screw.
Jun 09, 2011 | Delta & Single Handle Shower Faucet
I can't get the screw out of the handle of my delta single handle faucet to change the seats and springs. I think it must be stripped inside the handle.
In most cases you can use a self threading screw and screw it in the top of the stripped screw and slowly turn it out. Might have to use a tiny drill bit to pre drill first.
May 08, 2011 | Home
Cannot remove handle. Allen wrench receiver is stripped. Are there any other options? Thanks!
There is a home cleaning product called the The Works which will loosen the corrosion around the screw. Then use a screw extractor tool. You can find one at most hardware stores and home centers.
Another solution would be to call Moen Customer Support and ask for a new handle and repair parts for free. The faucet should have a lifetime warranty. When you have the new faucet parts in hand, literally cut the handle off the faucet with a hacksaw or drill the screw out to remove the handle.
Sep 07, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Replace entire valve assembly
You can drill a small hole into the set-screw and use an easyout to extract the set screw
May 04, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
Delta 2572-272 Chrome Coventry Centerset Bathroom Faucet Logo
109 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
