Question about KitchenAid KAWS850LE Top Load Washer
KitchenAid Washer with no spin
The washer was working yesterday and we heard a noise while it was spinning and we opened the door and the spinning started to stop so we closed the lid and it continued to run. Later the washer would function properly until it came to the spin cycle and would not spin? The washer is only 2-3 years old, top load.
  • 2 more comments
  • befireaz Jan 19, 2009
    Sorry it was a sock in the pump so we pulled the sock out and it works great now.
  • Anonymous Mar 10, 2009
    i guess its not spinning the clothes were wet after it finished
  • Jonathan Bendencio
    Jonathan Bendencio May 23, 2014
    285753A - FACTORY OEM GENUINE
    The part number for the coupler is: 285753A - FACTORY OEM GENUINE. It can be purchased on amazon.com as-well-as other online stores.
Here's a video.  http://repair2000.com/coupling.html
Posted on Apr 30, 2009
  • 530 Answers
Hi, so you have a kitchinaid washer that is not spinning and making a horrible noise.
More than likley you have a bad drive coupler. Which is located if you tip the unit back. not all the way, just enough to see the inerds of the washer. I usually prop it against the wall. There is your pump and attached to the pump is your motor. Between the motor and the transmission is your drive coupler. take the pump and motor off to gain acces to this part. there are 2 clips for the pump and 2 clips for the motor. usually 2 screws holding the clips for pump 2. Take the motor off and you will see the coupler. there is a grommet that goes between the 2 pieces sometimes that gets worn out and you will see black soot on the ground. That's a good indicationg that the coupler is the culprite
Posted on Jan 05, 2009
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Yesterday my ge wcvh626ohww washer was running through a spin cycle and I heard a (excuse my noise descriptions) thump like something broke loose, and it sounded like the drum was spinning very unusually...
I don't have experience with this particular machine but it sounds like it might be the drive belt. The following website might shed some light,... has videos. There are also sites which show parts diagrams.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-3-862537-/GE-Washer-won-t-spin-WCVH6800J1WW
Hope this helps a bit.
Mar 26, 2017 | Washing Machines
Kitchenaid kawe577bwh1 front load washer will not spin
Sounds like the timer might be defective. Try turning the timer manually to see if it goes into spin cycle. If it does then thats what it is. Hoped this helped if not let us know thankyou!
Mar 16, 2009 | KitchenAid KAWS850L Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Water does not drain, clicking noise heard no spin cycle
REMOVE DEBRIS FROM PUMP LOCATED INSIDE WASHER ,, REMOVE 2 SCREWS HOLDING BOTTOM PANEL,, PUMP IS PLASTIC TURN COUNTER CLOCK WISE AND REMOVE DEBRIS,, BE CAREFULL HAVE ALOT OF TOWLES STILL HOLD 3 GALLONS OF WATER
Nov 22, 2008 | Kenmore 43142 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kitchenaid top load washer will not spin
ck wiring to motor for loose connections at motor plug wiggle connector to see if motor will start
May 10, 2008 | KitchenAid KAWS750L Top Load Washer
Motor wont spin
whats makes the noise on spin if motor not turning at all.. i kinda confused... I Would check lid switch and see if maybe that might be the problem.. havnt had a lot of experince with hover but most washers have lid switchs to prevent spinning when lida opened
Sep 02, 2007 | Hoover AAA140 Front Load Washer
KitchenAid KAWS850LE Top Load Washer Logo
483 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
