Question about Hampton Bay 46056 Callaway II Ceiling Fan
54" Celining fan Callaway II. Model 526-062 or 526 017
We are looking to replace a 20 year old ceiling fan. We want a light fan with a remote.
Any suggestions?
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
  • 75 Answers
SOURCE: lost screws to attach fan blades on ceiling fan
This is not a 'promo' for Home Depot but you will find the screws there that you need.
You will need 15 screws, with an 'unfinished' appearance, for the attachment of the five blades to the arms, and 10 screws that have a smooth rounded finish to attach the arms to the motor housing. If they do not have it in stock they can order ot for you.
If you have an electrical fan store in your area you should be able to find the items there as well.
If you have an old discarded ceiling fan, take the screws out of it and try them on your current fan, they should work.
Good luck. :)
Posted on Apr 26, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
  • 3289 Answers
SOURCE: My Callaway II ceiling fan
If I recall, this fan has no external switches that can be operated - all of the fan and light functions are controlled by the remote alone. If this is indeed the case, there is little that can be done outside of hoping the problem is with the remote itself. If that is the case, replacing the remote is likely to be cheaper and less labor intensive - that is if you can find one.
From what I have read, this fan is no longer in production nor available for purchase. You may have luck bringing the remote to Home Depot - the main (possibly the exclusive) distributor of the Hampton Bay brand to see if they have fans on display that make use of remotes for fan and light control. If so, try to see if all your remote functions work. If you find that the reverse function no longer works - you should ask the sales associate about how to go about ordering a replacement remote. If the remote fails to work at all, you can 1) try a "shot in the dark" about ordering a an exact replacement remote - with the hopes that the remote itself is defective - rather than the paddle fan, or 2) start new by buying a new paddle fan with hardware switches for fan speed, direction and light operation AND a remote control module to perform a whole replacement of your existing paddle fan.
The "add on" remote control gives you many of the benefits of the remote only fan - but also provides a "back up" way to operate the fan should the remote or module fail. Had this been the style you have currently, you could operate the fan by hand until the remote and / or ceiling module was replaced.
I hope this helps and good luck. Please rate my reply. Thank you.
Posted on Jun 01, 2011
Remote does not work. Have relaced remote and receiver. Fan and light turn on and off at any time by themself!!
Change the frequency settings. Your neighbor's fan is probably on the same setting you have now. If you didn't have problems before you put in the new receiver, change to original settings.
Aug 24, 2015 | Hampton Bay 46056 Callaway II Ceiling Fan
My Callaway II ceiling fan transmitter shows that air is being pushed down. However, the ceiling fan is actually pushing air upward. I've tried everything I can think of to get the transmitter and...
Jun 01, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
My ceiling fan, at speed 5 also not rotating in full speed. I
Most likely the run capacitor has failed. Being 3 years old, I would not suspect the bearings.
May 16, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Fan goes in reverse instead of pushing air down it goes counter clockwise. How do i reverse it?
1.) this model uses a remote control controller to operate its functions
2.) the reversing is done via that remote.
3.) the link is wireless
4.) do you have the remote?
Apr 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay 46056 fan
I have three Hampton Bay Ceiling fans with remotes for eight years. I doesn't help when a neighbor buys the same make and model. So, I had to come up with a different code for mine. I had to change the code for the remote and match it with the code in the fan. To change the code in the fan, that depends on the type of fan you have, some you would need to look on top of the fan and use a skinny stick to change the code, other's you would need to take the light fixture down to get to the controller box to change the code. I have both types, this is how know. PS. if ever, which will happen, if the fan doesn't respond to the remote then you would need to replace the controller inside the fan. Here's the warrenty no. 800.749.3267 for replacement.
Dec 24, 2007 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay 46056 Callaway II Ceiling Fan Logo
127 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
