Synch problems with PDA and WMDC - error 0x80004005
Unable to synch my HP iPaq 214 get error message 0x80004005 - have tried reinstalling WMDC (Vista 32 bit system) - hard reset, different computer, removed open ended recurring appointments - but all to no avail - Please help!
  • 34 more comments
  • j_spitzer Jan 05, 2009
    I have tried that too (i.e. Win XP and Synch 4.5) and it did not work - Sorry! .....and anyway I do need to run it on a Vist machine. I'm getting very frustrated
    You (Mrright) say "Reload Software" Is that the WMDC (done that several times) or MS Outlook 2007?
    No PIE plus installed on my machine (as suggested by Findmeifucan)
    Renosean: Have tried that as well under XP didn't help - sorry,
    Sorry, still getting same error message!
    This is the same as the previous suggestion which didnt work!
  • j_spitzer Jan 06, 2009
    Tried it (yes there were errors in the pst file) BUT it didn't help iPAQ froze in the middle of synch and wouldn't even re set from a soft rest - needed hard reset to get it back to life again!
    Device is recognised and it has synched properly in the past until I got the error message
    Lots of work getting it to synch with bluetooth ...........BUT again still getting same error message - sorry
    Made no difference
    removing SD card and battery made no difference
  • j_spitzer Jan 07, 2009
    Worst advice ever! It chewed my registry up and cost me $30!! - its taken me a sevrtem restore and hours of work to put right - and I'm no further with my original problem!
    Same as last solution - see comment - don't try it it kills your registry!
    not able to do it myself - will get someone to help me
    Thanks WorldVet - excuse my ignorance but how do I do that and on which specific directories? - I'm trying to sync with Outlook 2007 to an iPaq 214 PDA - Thanks
    Can't remember what the error message was on XP - am now using Vista and no longer have acess to the xp computer
    Rename or delete sync.log file on your pda
    \\windows\activesync\ - didn't help
    Have tried synch each part separately - I think its my calender that's the problem
    NB I have to perform a hard reset each time I try any of these suggestions as the calender and contacts freeze up after each attempted synch (of the calender)
    have tried 2 vista computers - no luck!
  • j_spitzer Jan 08, 2009
    I'm not too familiar with editing the registry, but following the instructions in the ODBC permissions I changed everything (that would let me) to YES (or ticked the box) Unfortunately this did not help - did I do it right?
    Thanks, but I have done this many times and between trying every suggestion posted i do a hard reset - not (yet) helped
    Yes I am running Norton antivirus
    sorry, but I don't understand what you intend that I should do?
    I've done that (hard reset) many many times but I always get the same problem - I'm getting very frustrated!!!!
    Proxycfg -d -p * ";servername of WSS;FQDN of WSS;ipaddress of WSS"
    Tried that and get the following message "Proxycfg is not recognised as an internal or external command,opperable program or batch file"
    NB I'm on a stand alone laptop not a networked computer
  • j_spitzer Jan 10, 2009
    Registry fixing software destroyed my registry, and cost me $30 for thge priveledge! I had to do a system restore to undo the damage. Unless I know EXACTLY what to edit in the registry and how to do that, I'm not going that route again.
    Thank you - but I have been through all that before contacting FixYa! So sorry but I'm still stuch with my problem
    What SPECIFIC registry problem - and how do I correct it?
  • j_spitzer Jan 11, 2009
    Sorry downloaded what? - NB I've not downloaded anything at all via my PDA
    Still not solved my problem, any new ideas?
    I've done all the permissions as instructed on PRB: Error Message: 0x80004005 not made any difference
    I've tried most of the suggestions so far, but I'm no further - any more suggestions? - What if I wipe my hard disk and reinstall Windows and all my other programs (Rather drastic very time consuming)? will it help? will I get the same problem again? How do I know I won't get the same problem a few weeks down the line? All I wan't is to get my PDA to synch reliably with my Outlook files.
    I have tried switching Norton off completely - no change! NB I don't use my Outlook or PDA for emails - only for contacts/calender/notes/reminders
    Thanks, but |I have to do a hard (factory) reset between each attempt at synchronizing as the iPaq becomes unstable and freezes after each unsucessful 0x80004005 errer
    Thanks, but |I have to do a hard (factory) reset between each attempt at synchronizing as the iPaq becomes unstable and freezes after each unsucessful attempted synch giving the 0x80004005 error
    I assume you mean a hard or factory reset? - Done that many time. But, still no use
    still not solved my problem - Can anyone please help?
  • 818 Answers
Upgrade the bios
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=215348&prodSeriesId=3544060&swItem=hh-63163-1&prodNameId=3544117&swEnvOID=4014&swLang=8&taskId=135&mode=4&idx=0
and make a reset.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3544060&prodTypeId=215348&objectID=c01334816
Thanks
Sergio
Posted on Jan 11, 2009
  • 470 Answers
The general problem on it is the internal software, you need to reprogram it,, because the software is not properly organize
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 18, 2009
    You remove activesync, and reinstall and still no sync. You check
    device manager, remove the com port driver reboot reinstall and still
    no sync. This is actually a common problem, but it's not documented.
    Windows by default will increment the com port assignment each time it
    detects a new device. It does so automatically via plug and play
    interface. So if you see your outgoing or incoming port assignments in
    device manager listed with any number above 8, then your pda will not
    sync. Most ipaq's (and other windows mobile based pda's) sync with a
    windows pc but you must use a com port assignment below port 9. Also
    this might sound a little confusing at first, because most pda's are
    connected via the usb port. But note that the actual com port
    assignment is virtual and basically used as the interface. It has
    nothing to do on how your pda is physically connected. Meaning the tip
    here works if you are connected via serial, usb, bluetooth or even via
    wi-fi link.
    adparams.getadspec('c_billboard1');
    Simply removing the com port doesn't work, because as already stated
    windows will increment the port number each time a new device is added.
    Which is in essense what you are doing when you remove a com port
    entry, and try to reinstall your pda.
    The solution is simple, select any communications port number under port 9, and you will have no problems.
    To change the com port assignment do this: Right click on my
    computer, properties, then right click over com port 9(or whatever new
    com port windows just assigned to your pda) and select properties,
    click on port settings tab, then advanced. On the bottom of this screen
    use the drop down menu to assign it a different number. Remember it
    must be under 9. Just as long no other device is using that number then
    you'll be fine.
    Sniper:
  • 59 Answers
Hi did you try download it from your pda
Posted on Jan 10, 2009
    Scholar:
  • 100 Answers
What OS do you run on your iPaq ?
Windows Mobile Device Center supports the following features/versions of Windows Mobile:
  • Microsoft Windows Mobile 5.0
  • Messaging and Security Feature Pack for Microsoft Windows Mobile 5.0
  • Microsoft Windows Mobile 2003 Second Edition
  • Microsoft Windows Mobile 2003 RESOLUTION
  • Anas Al-Mustafa
    Anas Al-Mustafa Jan 10, 2009
    Windows Vista does not support Pocket PC 2002 and earlier versions. Devices with Pocket PC 2002 and earlier versions must continue using computers with Windows XP or earlier operating systems.
  • Anas Al-Mustafa
    There's one thing you can try, which is the following:
    go to control panel then to add/remove programs then on the left side there's Add/Remove windows components click on that.
    then scroll to Internet Information Services and make sure it has a check beside it. if it doesnt then click it and press apply or OK then it will ask you for a WinXp or Vista in your case, put the CD inside and click ok to install Internet Information Services.
    Now login using administrator account and hopefully your phone will sync.
    let me know if that works?
    Sergeant:
  • 431 Answers
It is due to the regestry problem
    Genius:
  • 1,011 Answers
Sir,
Click this link to solve the problem
thanks
good luck
Posted on Jan 08, 2009
    Guru:
  • 829 Answers
Its a registry issue , Get it fixed. or download registry fix software and clean it should fix the error.
  • 2,071 Answers
This is a conflict when Windows Microsoft is updating and maybe the Ipaq registry is damaged already. Just try a soft reset will fix your problem. I think you need to perform a clean reset. A clean reset will remove all your user files, any software you've installed to it, and any user settings you've added to it and will restore the pocket pc to its factory settings. It should not affect anything you have on an SD card, but remove the SD card when you do it.
Hope it may help you;
Regards;
VOTIT
  • LORETO LACARON
    LORETO LACARON Jan 08, 2009
    Just click below ;
    http://www.hardreset.eu/hp_ipaq_214_hard...
  • LORETO LACARON
    LORETO LACARON Jan 12, 2009
    Try this solution maybe of help;
    1. Make sure your Windows Mobile device is unplugged from your system during the next four steps.
    2. Uninstall your previous Windows Mobile Device Center/Windows Mobile Device Center Driver Update installations.
    3. Reboot.
    4. Reinstall WMDC 6.1 fromhttp://www.microsoft.com/windowsmobile/d... Wait until all device driver installation dialogs have stopped appearing (which can/will continue after the WMDC 6.1 installation has completed).
      Click here for Windows Mobile Device Center
    5. Plug in your Windows Mobile device and wait until all device driver installation dialogs/balloon pop up signals are completed. WMDC should now let you create a new partnership.
    Scholar:
  • 143 Answers
U need to change driver also install .net fremwork it's help u
    President:
  • 1,952 Answers
I would do a hard reset. Since this will return the
phone to factory defaults,
    Scholar:
  • 111 Answers
Are you running Norton Antivirus?
  • Curtis Tuendemann Jan 08, 2009
    "Hi Janet D. I was having the exact same problem and finally figured out
    the problem tonight. The Yahoo POP3 server was telling my computer that
    there were 19 new email messages to download, but in reality there were
    20 new messages. This was causing outlook express to fail with the
    0x80004005 error. Here's what I did to fix the problem: I logged into
    my account on the yahoo website and went to my email page on the web. I
    then created a new folder called "temp" in my webmail account. Then I
    moved all my new emails from my webmail inbox to the new "temp" folder.
    Then I moved all those new emails right back to my webmail inbox, and
    that fixed the incorrect count. After that I ran outlook express and
    sure enough, it downloaded all my messages with no problems.
    Just note that the 0x80004005 error is used by Microsoft for alot of
    different reasons, so your problem may not be the same as mine. One
    sure way to tell is to count the number of email messages in your
    webmail inbox when you log into your yahoo account online. See if that
    number matches the the number that's displayed next to the "inbox"
    word. If the counts don't match, then you're having the same problem as
    I had."
    Found this on the Yahoo messege board originally posted by "Jim C"
    Alot of people are pointing the finger at norton
    "To work around this issue, use one of the following methods:
    Method 1: Disable Script Blocking in Norton AntiVirus
    Warning
    This workaround may make your computer or your network more vulnerable
    to attack by malicious users or by malicious software such as viruses.
    We do not recommend this workaround but are providing this information
    so that you can implement this workaround at your own discretion. Use
    this workaround at your own risk.
    In Norton AntiVirus, turn off the "Enable script blocking" feature."
    After some extensive research I found those options hope they work
    Sergeant:
    Novelist:
  • 326 Answers
Try to check out that on any other pc having the same vista operating system.that may confirm the exact fault where the problem lies.
Posted on Jan 07, 2009
    Guru:
  • 859 Answers
You've had some good suggestions so far.
Primarily what you need to do is set permissions on all dicrectories that you want to sync with.
Its nothing more than that. Open each folder and set permissions to change for that folder an you will be okay.
It shouldn't come to this actually. It should be straight forward. But, its not, so make these changes and you should be OK?
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Jan 07, 2009
    Hi, Just got an email alert that this is still open. When using syncing software I have found that setting permission in the folders solves many problems.
    What you do it right click the folder holding the data and on the property sheet for that folder there is a check box to Share this... etc. and another to let users change contents. This is what I check off for all my syncing tasks.
    Its pretty self explanatory, but let me know through an Ask Me question if you need further assistance.
    Worldvet
    Sergeant:
  • 237 Answers
Go to this website and download the repair tool to fix the error 0x80004005:
http://www.errornerd.com/error.php?seed=0x80004005&gclid=CLKW-bjH-pcCFRdinAodZ1aaCg
Posted on Jan 06, 2009
  • zabrina liang Jan 06, 2009
    Did you download the repair tool ?
    I'm sorry< but did you use the repair tool I sent you to?
  • 4,806 Answers
Hi there
There is problem with the registry and the PDA cannot sync with any machine.
Firstly perform a Microsoft update on the PDA and make sure its up to date.
To resolve this issue on a computer, use one of the following methods:
  • Use a host name, such as: http://projsvr2003/ProjectServer to connect to the Project Server Web site.
  • Use the WinHTTP Default Proxy Configuration Tool to add the FQDN to the Bypass List.
To add the FQDN to the Bypass List, follow these steps:
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following command line, and then press ENTER: Proxycfg -d -p * "<local>;servername of WSS;FQDN of WSS;ipaddress of WSS"
  3. At the command prompt, type iisreset and then press ENTER. The iisreset command stops and then restarts Microsoft Internet Information Services (IIS).
Also perform a genuine advantage diagnostic from the Microsoft site >>>>>>>
http://www.microsoft.com/genuine/diag/
Good luck and kind regards
    Scholar:
  • 86 Answers
This should fix it:
http://www.errornerd.com/error.php?seed=0x80004005&gclid=CIqKj5DD-pcCFQxKGgodvFH0DA
Please click on link indicated above.
Thanks.
  • 716 Answers
Turn Off Your Fire Wall Then Try It.
  • Michael Fisher
    Michael Fisher Jan 07, 2009
    Use a host name, such as:http://projsvr2003/ProjectServer
      Proxycfg
      of WSS;FQDN of
      WSS;ipaddress of
      WSS"
    Genius:
  • 1,913 Answers
Remove your memory card then try also change battery.
  • kishor khatri
    kishor khatri Jan 07, 2009
    reset your ipq to factory defaults.remove baatert also remove memory card then clean dust form all circuit.then againa ttached thenstart .
  • 51 Answers
I chatted with omeone for 3 hours on this issue, with almost no luck. This is what ended up solving the issue:
sync ipaq with vista using Bluetooth
http://forums.microsoft.com/windowsmobile/ShowPost.aspx?postid=3427694&isthread=true&siteid=65&authhash=5ab61ea33c1bcd8180534a1b8d8cbab85de34759&ticks=633479378241863470
If this is not an option, please follow the following procedure:
Or, if you do not have bluetooth on your pc, you can do this:
-Import your personal contacts and calendar into the Windows Contacts/Calendar that comes with Vista. You might have to convert the .pst file into a different format first.
Let me know if this works out. Good Luck!
Posted on Jan 05, 2009
  • 565 Answers
Microsoft replaced ActiveSync with Windows Mobile Device Center, an improved version of the software for use with computers running Windows Vista. You must use this new program to sync your Windows Mobile device in Windows Vista. The first time you plug a Windows Mobile device into a computer that is connected to the Internet and running Windows Vista, Windows Mobile Device Center should automatically download and install on the computer. After you set up your device to sync in Windows Mobile Device Center, the sync results will appear in Sync Center.
If you are unable to get a device to work with Sync Center, it may help to check if your device is listed in Device Manager. Even if Windows recognizes your device, however, it might not be compatible with Sync Center.
You must be logged on as an administrator to perform these steps.
Open Device Manager by clicking the Start button Synch problems with PDA and WMDC - error 0x8000400 - getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
http://windowshelp.microsoft.com/Windows/en-US/Help/1074e034-1bcf-4dfb-93c3-46ec7df97d371033.mspx
if helped rate fixya
    President:
  • 2,110 Answers
Repair errors by using Scanpst.exe
  1. Exit Outlook if it is running.
  2. Double-click Scanpst.exe, located at drive:\Program Files\Microsoft Office\OFFICE12.
  3. In the Enter the name of the file you want to scan box, enter the name of the .pst or .ost file that you want to check, or click Browse to search for the file.
  4. To specify the scan log options, click Options, and then click the option that you want.
  5. Click Start.
  6. If errors are found after the scan is complete, you will be prompted to start the repair process to fix the errors.
    A backup file is created during the repair process. To change the default name or location of this backup file, in the Enter name of backup file box, enter a new name, or click Browse to look for the file that you want to use.
  7. Click Repair.
  8. Start Outlook by using the profile that contains the .pst file that you tried to repair.
  9. On the Go menu, click Folder List. In the Folder List, you may see a folder named Recovered Personal Folders that contains your default Outlook folders or a Lost and Found folder. The recovered folders are usually empty, because this is a rebuilt .pst file. The Lost and Found folder contains the folders and items recovered by the Inbox Repair tool. Items that are missing from the Lost and Found folder cannot be repaired.
  10. If you see a Recovered Personal Folders folder, you can create a new .pst file, and drag the items in the Lost and Found folder into the new .pst file. When you have finished moving all the items, you can remove the Recovered Personal Folders (.pst) file, including the Lost and Found folder, from your profile.
    Genius:
  • 1,689 Answers
Thank you for using fixya. the error is all about RegSvr32, may have been triggered when you loaded the software on your computer. please try to check the link below to see how it can be resolved.
Troubleshooting 0x80004005
Hope this helps.
  • 19,396 Answers
The error is on windows, and is because of windows permissions. You need to log in as administrator , or on account with administrator privileges and modify entries on windows registry, so to change security and permissions settings, see:
  • Ginko
    Ginko Jan 07, 2009
    To start, do not download regcure, and do not pay them, see: RegCure Software Complaints - Regcure Software killed my PC!
    The link had been posted by mistake by some new expert.
    As I told you before, the problem is related to windows ODBC settings on Windows Registry, and effectively the registry must be manually edited by a technician, as if you do things incorrectly Windows may not restart.
    Often you can also fix the problem with system estore, as this will report the computer registry to a previous date.
    The problem affects Outlook and other applications that need ODBC.
    Make a safe registry backup using export on registry editor if you decide to do modify registry.
    Possible solutions:
    1 Microsof solution, modify Windows Registry :PRB: Error Message: 0x80004005
    2 Do system restore, this restore Windows registry to an earlier backup.
  • Ginko
    Ginko Jan 09, 2009
    Hard reset has nothing to do, you need to ask a technician to work on your registry manually, or do it a t your risk.
    It is days that I am posting the comment from Microsoft with the solution here: PRB: Error Message: 0x80004005
    Bother to read it and print it out.
  • 492 Answers
You need to update the active sync on the PDA. This can be done from the windows mobile homepage and or done by installing the newest version of windows mobile. You will need to do this from a non vista computer as you will need to have active sync functioning on a computer to get it to install.
    Genius:
  • 1,550 Answers
If you have installed PIE Plus v2 then uninstall it .The problem is caused because of this . Try to completely delete it .
    Sergeant:
    Scholar:
  • 199 Answers
It is the software issue needs to be reloaded again.
  • 13,433 Answers
Please try it on a windows xp computer with active sync 4.5 installed.
Wont sync with windows 7
If you haven't already done so, try to uninstall and reinstall WMDC on your PC. Reset both your PC and PDA, and try again.
Just my 2 cents... Carlos
Apr 16, 2010 | HP iPAQ 111 Classic Pocket PC
My home desk top says this UBS device attached to this computer has malfunctioned and windows does not recognized it and calls the device unknown.
Firstly, reboot both your PC and PDA. If they keep failing to connect, delete the partnership between them, both on your PC and PDA. If they keep refusing to connect, remove ActiveSync (for WinXP) or WMDC (for Vista & 7) from your PC and reinstall it.
Hope you are able to have your device synced soon.
Cheers! Carlos
Apr 13, 2010 | HP iPAQ RZ1710 Pocket PC
Cannot synch I need get started software but
Forget Samsung's web. Use Google to find ActiveSync 4.5 (if you're using WinXP) or WMDC 6.1 (if using Vista). Install then connect your Omnia and follow on screen instruction.
Oct 10, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Hp ipaq 214 PDA
As far as I know active synch which is the default app, does not support synchronizing subfolders. It is no question of firewall or antivirus, unfortunately microsoft designed it this way. There is a third party application though, Intellisync which is going to enable you to synch subfolders, however they will appear all in one big folder on your IPAQ.
Alternatively it will however take over the settings if you categorize the contacts and that has nearly the same "effect" as if you used subfolders. If you choose to use categories, then you can even keep your normal active synch, cause that it will synch fine. Not a bad thing cause third party applications are never perfect and Intellisync is unfortunately not free. You can add the categories to your contacts even while keeping your original subfolders in outlook, just match the categories to them and it will "look" perfectly the same on your IPAQ but yes you have to edit contacts one by one, so this is a one time big job then.
Jan 26, 2009 | Computers & Internet
PDA iPAQ 214 WMDC - synch error 0x80004005 - ongoing
Yes. The permission is inherited by all sub folders.
Jan 08, 2009 | HP iPAQ H1940 Pocket PC
HP iPAQ 110 will not active sync
no operating systems stated,
windows 10? what?
why would a battery this old be good, if was, its like world record.
buy a new battery ,better upgrade to smart phone.
sync
but the HP end and the Microsoft end have to have compatible and working drivers. to work.
the 110 is dead product at HP
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544497
your only hope is talking to Microsoft now,
see if they support it, my guess w10 does not
how far back , support software drivers ended, ask MS.
looks like (hard to track) w7 is last OS supported.
i see scalpers selling drivers now, for this old product.
good luck with them,,,
try asking on a real HP forum
other asked this vast times, and the answers are dead correct.
http://h30434.www3.hp.com/t5/Calculators/Synchronization-involving-HP-iPAQ-110-and-Windows-8-PC/td-p/5078151
excerpted
Unfortunately, WMDC is not compatible with Windows 8 and you will not be able to sync your Outlook related data to your iPAQ. There is no expectation that Microsoft has any plans to update WMDC to make it compatible.
You may be able to use a third party paid application to sync the data, like Companion Link or Akruto Sync.
Mar 19, 2017 | HP iPAQ 110 Pocket PC
I cannot get my new ASUS A626 to synch to my PC I am running Vista.
I am having the same problem and according to the computer experts at Staples in Montana they say that there is an upgrade in Windows that we need to download to the A626. However, I have searched Windows and not found anything so, I am off to Staples to have them fix it for $10. Best of luck everyone.
Oct 18, 2007 | ASUS MyPal A626
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Computers & Internet Logo
David Payne
David Payne
