Question about Whirlpool LSR5132PQ Top Load Washer
Washing but stops in the middle on the wash cycle and then won't continue...did have an overload issue the day before.
I had an unbalanced load the other day. After that the washer will start fine. But it stops in the middle on the wash cycle and won't go anywhere else.. I looked for a rreset button like suggested in other places here but have not found one. I'm not sure what model mine is either because it was bought years ago at a second hand store. Any suggestions? It aggitates the clothes just "freezes" up. Thanks for any help!
  • 883 Answers
Open the panel holding the timer switch (or cycle selector). look for disconnected wires
Posted on May 23, 2007
My cabrio washer squeaks when I start it and it's spinning also stop spinning in the middle of a cycle I have to redo the load and it still says uL what's wrong
ul usually stands for unbalanced load,if a top loader then suspension rods have worn out, fron loaders are more complicated
Jul 15, 2018 | Washing Machines
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
Machine was overloaded and now the spin cycle will not work
hum check the belt if applicable, the door switch just in case co incidence plays out here, also may have a bad clutch or motor coupler, or worse case problem ur tranny. are u saying it still washes though? overload should not throw out ur spin cycle but can damage ur clutch and tranny? lest u have a digital electronic board on this machine and they are know to go bonkers. some machines actually have a auto fixit for overload or unbalanced issues.
Feb 18, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My affinity front load pauses in middle of cycle and stops. Now there is standing water in washer
this usually happens when there is an unbalanced load? other wise u may be having timer issues
Sep 27, 2014 | Washing Machines
LG washing machine direct drive when i put it on it washes and goes down to 9 mins then stops, sometimes an error code comes up UE? CAN U HELP PLEASE
It means Unbalanced Error, it means the machine cant balance the load during the spin cycle, normally happens if there is too little a load i.e 1 or 2 things or overloaded. It is designed to protect the bearings. If it happens with a normal load try stopping it and re-arranging the load by hand and putting it on a spin only cycle. Hope this helps.
Feb 28, 2011 | Washing Machines
My washer's digital time screen changes from the time remaining to a symbol that looks like "UL".
This error code indicates that an unbalanced load is detected.
Click the following to learn more about unbalanced loads in the BravosTM washers. The example is for an impeller washer but is applicable to washers with agitators.
Is the wash load balanced?
If the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
Is the washer level? Does the washer rock when pushed against the corners?
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened. See the Installation Instructions for details.
To remove the error display, press Power/Cancel or Pause/Cancel once.
Jan 02, 2011 | Maytag Bravos MTW6600T Top Load Washer
Error code UL with 12 minutes remaing on each load
hi,
if the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
If Power/Cancel or Pause/Cancel does not work
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start/Pause.
Sep 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Unbalanced load- spin cycle stopped . cannot get machine to start
Hi just read your posting .Do you still require help?If so reply back and I am sure I can help you.
Jul 12, 2010 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
143 people viewed this question
Sal De
Marvin
Marvin
jimorris77
