Question about Locks & Locksmithing
How do i set lock on axa ntc=95 combination lock
Bicycle combination lock
With the lock open (!) (with the right combination set, push the gray buttons backwards so the lock opens), then rotate the right triangular marker clockwise 90 degrees, then turn the numbers to set your new code, then place the right triangular marker back to it's normal position. (rotate back 90degrees counter-clockwise).
Took me a while to find out too...!
Posted on Feb 05, 2014
2 Suggested Answers
  • 61 Answers
SOURCE: problem with chain bicycle lock
Don't know this particular lock but can you part chain with cycle chain tool? If not I would protect drive chain and gears and attack hasp with metal cutting wheel in angle grinder. Few locks can resist this for more than a few seconds.
Posted on Oct 31, 2009
How do I set an abus 1460 combination lock
Your lock is here Linda, but no instructions
https://www.abus.com/eng/Mobile-Security/Bike-Safety-and-Security/Locks/Steel-O-Flex/Steel-O-Flex-Raydo-Pro-1460
there are a number of videos showing how in the main link. This one is good;
https://youtu.be/ZyPmi1o_o1M
This one has the key built in
https://youtu.be/m32HP5E8Ak8
Go to Bing homepage
Jul 21, 2016 | Abus Raydo 1460 Lighted Combo
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
How to set the combination on a Blackburn ANGOLA COMBO CABLE LOCK
Open the lock using the original combination, which was 0000 for mine. Once open, you will find two tabs on the lock side--on top and bottom of the lock portal. Push in both tabs, and hold them down while you set the new combination. Once it is set, put the post back in to make sure it is still open. Twist the dials to lock it, and then you should be able to unlock using your new combination.
Feb 23, 2014 | Bell Blackburn Angola Combo Cable Lock
Have just purchased an 8mm Tioga resettable combination bike lock but stupidly threw the packaging with instructions on how to reset the combination... currently set at 0000.
I realise this is an old question, but...
Open the lock with the default combination (0-0-0-0)
At the insertion point you will see a raised ring to the right of the numbers. Turn this part clockwise (it has an arrow on it). Set the combination you want. Turn the ring back, anticlockwise. All done!
Sep 15, 2011 | Tioga Cycling
I have a bell bike lock and i lost the instruction manual so i need to know who to set a lock code
Open the lock. (default = 0000)
Look into the center of the cone.
You should see SET with an arrow
Turn the center tab or dial away from SET direction
Set the combination
Turn the same tab or dial to the SET direct.
Test the combination
Sep 06, 2011 | Cycling
Just purchased my sunlite lock but the directions where thrown out by the retailer.....how do i set my lock combonation? I have it on all zero's now and it is unlocked...thanks
We just got a sunlite lock and figured it out. After it is unlocked with 0000 and the lock opened, the end spins to a "set" position. Set the numbers you want, spin the end back, and lock will be set to those numbers.
Jun 30, 2011 | Sunlite Coil Cable Resettable Combination...
No directions came with Master Lock 8143d. Do not know how to set combination to unlock and then set for my use?
The information "out there" is that this is a fixed combination lock, meaning not changeable.
Mar 13, 2011 | Master Lock Cycling
Hi, I bought a Krypto bicycle lock over 5 years ago. I don't see it displayed on your website. It has yellow ends with 4 digit combination numbers red on black.The rope cable is grey and has a clear...
Krypto has the resetting of the combination lock on their website (under Maintenance) but if you cannot unlock it in the first place you can not reset the combination. You have to know the old combination to get it open.
Feb 23, 2011 | Kryptonite Cycling
Locks & Locksmithing Logo
302 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
