Question about ASUS P4XP-X Motherboard
Pentium-mmx...hard disk diagnosis fail..disk boot failure 166Hz toshiba cd rom 1984-95 xm-5302TA help i have no idea what this means trying to fix my parents computor..is there a boot disk i can download....?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    OS is not present in hard disk pls try to install windows or change hard disk if it is failed
    Genius:
  • 1,066 Answers
Its called the "ultimate boot diak" go google it.
Posted on Mar 11, 2009
How can I fix reboot and select proper boot device or insert boot media in selected boot device and press a key on Toshiba satellite C55D-B5308
A number of things can cause this:
1- Your Hard drive is\has failed (meaning, the the computer can't read the Hard drive)
2- The OS (Operating system) is not installed\corrupt.
3- There is a disk in the CD-Rom and your laptop is set to look at the CD-Rom for a OS
Some suggestions:
1- Replace hard drive
2- Try reinstalling the OS or doing a "repair" (Turn off, then back on, press F8 while it's booting up until you get a safe mode screen, chose the option to repair)
3- Check your BIOS settings (Press F2 or delete while booting it up)
Nov 19, 2017 | Toshiba Computers & Internet
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
Starting up i get PXE-E61 media test failure some people tell me its the hard drive some say the cddrve others say it could be trying to boot from a LAN
PXe Boot is used by the computer to boot to a network DOS-type environment.If you are receiving a PXe failure message on bootup check that your PC is set to boot from the CD Rom, Floppy, and Hard Drive BEFORE network or other boot device.
That's where you need to check to get solution to your problem, if not... try these
1. your settings in your bios
2. faulty cable/wire to your media device (hard drive, cd/dvd rom, etc)
3. The cmos battery (which indirectly points to your bios settings)
Hope this helps!
Jul 18, 2011 | Toshiba Satellite L455D-S5976 Notebook
Latest firmware?? Where download?
http://www.eid.toshiba.com/support/swdrivers.shtml
If the boot disk came with your laptop, it should have the necessary drivers on it. You cannot burn drivers on your CD-Rom boot disk because it is not made of the material suitable for laser burning. Even if it were, it would have been "finalized" and the CD writer would not burn it.
First of all, you have to enter the BIOS Setup to see if the drive is detected. If not, then you have a hardware problem, loose connection or bad drive.
Boot to your C: drive and go to the Toshiba link (above) to download the drivers. Then install the CD-ROM via Control Panel>Add Hardware route.
hope this helps
May 15, 2011 | Toshiba XM 1802D (XM1802D) Plug-In Module...
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
Toshiba Satellite A215-S4747 does not start up.
Have you tried booting from a cd?
It sounds like you hard drive has failed.
Dec 31, 2009 | Computers & Internet
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Trying to run recovery disc on computer and cd rom isn't reading
I see this as one of 2 possible failures.
  1. Optical drive failing. Take out the Hard drive, see if the recovery disk, or another bootable disk will boot. If no change, replace the optical drive.
  2. Hard Drive failing. If the system will boot to a CD with the HDD out or if replacing the optical drive has no change, then the HDD is the next logical failure point.
Apr 02, 2009 | Compaq Computers & Internet
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
I have a laptop Toshiba satellite A30. I have a black screen and some text on it like: PXE-E61 MediaTest Failure PXE-M0F Exiting PXE ROM and it goes continiously, I can't go any further. When I was loaded...
media test failure means that your boot drive has failed ie your hard drive has failed to boot....could be one of a number of reasons
1 hard drive connection could be loose - try taking out the hard drive and reinstalling it
2 the boot sector on the hard drive is corrupt or damaged - try booting off a windows disk and running chkdsk or fixboot command
3 partition table is corrupt - try booting off windows cd and running chkdsk /p from command prompt
4 Hard drive has failed - if machine is still under warranty return for repair if not install new hard drive and reload op system from recovery disks
Dec 05, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
ASUS P4XP-X Motherboard Logo
301 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
