Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore #362.75211101- gas oven will not come on
I have a gas range and the oven will not come on. Has electric egnite .Can see glow coil on but no gas getting through for burner
catriver
  • 878 Answers
SOURCE: burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Posted on Apr 10, 2007
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite gas range the oven burner doesnt light right
It appears your gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Testimonial: "thank you"
heatman101
  • 43501 Answers
SOURCE: Gas oven on Kenmore range model 362-75191890 went
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 27, 2010
Oven quit working. stove top works
the oven has a glow plug to ignite the gas. remove bottom tray in oven, and turn it on. if glow plug does not get hot, it should be a bright orange color. replace the glow plug if it does not operate properly. if you do it yourself. be very careful. the glow plug is very fragile and must be handled with care. Ive broken one before! just a slight tap will break them. good-day! ( for electric ovens).
Apr 09, 2014 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
I have a kenmore range. The problem that I am having is that the oven will not come on and the electronic area to set the temp to the oven will not come on. The Stove Top will work but that is it. Please...
THERE IS A WHAT I CALL A GLOW PLUG IN THE BOTTOM OF THE OVEN . WHEN YOU FIRST TURN YOUR OVEN ON THIS PLUG SHOULD GLOW RED AND VERY BRIGHT, IF IT DOESN'T YOU WILL HAVE TO REPLACE THIS ITEM AND THAT SHOULD FIX YOUR PROBLEM. WHEN YOU FIRST TURN THE OVEN ON THIS GLOW PLUG HAS TO GENERATE A LOT OF HEAT TO LET THE GAS VALVE KNOW THE IT IS OK TO OPEN IF THE GAS VALVE DOESN'T GET THIS SIGNAL FROM THE GLOW PLUG THE OVEN WILL NOT COME ON
Dec 24, 2010 | Kenmore 46564 / 46565 / 465 / 6646569...
I have a Kenmore gas range . The oven won't ignite. The ignitor gets hot , but it acts like there is no gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Just because it glows that does not mean it is not bad...
heatman101
Sep 01, 2010 | Kenmore 45702 / 45704 / 45709 Dual Fuel...
When you turn on the oven the egniter glows, but it may take several minutes for the thing to light. sometimes you smell gas and sometimes not.
This is usually a sign that the ignitor is wearing out. Even though it glows, it is pulling just barely enough current to cause the gas valve to open. A new ignitor should take care of the problem.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE Gas Range/oven Model JGBS16 The glow coil in the oven works intermittently. When it doesn't come on we find that turning the control knob on and off several time will help or if we start one of the...
could be a bad thermostat but it sounds most likely like a loose wire connection somewhere. if the coil comes on and doesnt quite glow as bright as it should, the glow coil needs replacing.
Oct 10, 2009 | GE JGBS17 Gas Kitchen Range
Need to light pilot light?
does the gas ignite at all. you shouldn't have to light a pilot. if the oven is not igniting you most likely need an ignitor or glow coil as it is sometimes called.
Oct 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Bake function not working
Yes, you need to replace the igniter.
If you're comfortable splicing wires, you can order any ignitor of the same shape, otherwise go to searspartsdirect.com to find the exact replacement part.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Jul 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
47 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
