Question about Maytag Performa PAV2200
Gas dryer work but doesn't get hot
My Kenmore gas dryer (Model 76914690) seems to work just fine but the pilot doesn't light and it doesn't get hot. Everything inside the dryer is sealed...how do I get to the coil, ignitor, etc.?
Tell your natural gas company that you smell gas around your gas dryer and you think there may be a leak. They will send somebody out, at no cost to you to check on the appliance (gas dryer). When that person gets there, they will re-light your appliance and if the gas dryer needs a new thermal coupler, they will show you where it's at and how to replace it.
Posted on Jan 16, 2009
Kenmore gas dryoer model #11073912100 not getting hot, all vents cleaned out, still won't work. could it be pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 11, 2011 | Kenmore 74112 Gas Dryer
Everything works it just doesnt get hot i think the heat is out
i would suggest a professional,,unless you are familiar with gas,,,pilot lights,,and thermolcouple's,,although you should be able to safetly observe if the pilot light is lit.
Jan 29, 2011 | Kenmore 73952 Gas Dryer
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
My dryer wont get hot . think the pilot is out . .. how do i relight the pilot
send the model number,you can't light the pilot anymore,they are electronic ignition now,is it gas or electric?find the model number around the opening where you put the clothes into dryer
May 08, 2010 | Kenmore Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
My dad has a kenmore dryer and cant get the pilot to light.how do i identify what model it is?
kenmore usually put there model plates under the lid on one of the lips,,,,
you can look on the back of the control panal as well
Nov 02, 2009 | Kenmore 84052 Dryer
Dryer goes on but does not heat up no flame
No flame indicates that this is a gas dryer?
If so, there has to be either a pilot light, or an ignitor. If it has a pilot light, make sure that it is lit. If it isn't, the gas will not flow. The sensing bulb above the pilot light must be hot before it will allow gas to flow.
Aug 14, 2009 | Kenmore Dryers
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Washing Machines Logo
220 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
