Question about Singer Sewing Machines
Threading singer 111w153
Have been given an old Singer 111w153 walking foot machine and would like to know the proper way to thread it and to wind bobbins.
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 7 Answers
SOURCE: was given an old model Singer 237 Fashion Mate
If the bobbin is in the casing correctly then follow these steps...spin your wheel toward you until the threaded needle drops a thread around the bobbin casing it will slide down around the casing from center to the right and down. one the thread is just over half way around gentle pull the tail of your thread from the needle. It should move up and to the left collecting the thread from the bobbin casing. and a loop will arise below your presser foot (which should be up).pull that loop up until the tail of the bobbin is visable. Now you are ready to sew.
Posted on Aug 16, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
I am after a manual for my Singer 1832U machine. I am having problems with looper threads snapping
Singer 1832U Manuals
Usually, breaking threads are a result of misthreading. Remove all the threads from the machine. AVOID old or bargain bin threads! ALWAYS RAISE the presser foot and rethread from the beginning--make sure each thread is threaded in the proper order.
Jul 17, 2017 | Singer Sewing Machines
How do you get the auto threading and wind in place to work on Singer XL6000 sewing machine
There are several FB and Yahoo groups dedicated to the Quantum XL-1000, XL-5000 and XL-6000 who can help you. It may be that your problem with the autothreading is the autothreader is out of adjustment, but I'm at a loss as to the bobbin winder problem.
Jul 15, 2014 | Singer Quantum XL-6000 Computerized Sewing...
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
The machine sews on top but not on bottom
Check the manual, if you do not have one, you may find one at Singer or sewusa websites.
Make sure the bobbin in installed correctly so the thead is feeding from the bobbin spool in the proper direction and through the correct guide(s).
Always thread the top thread with the presser foot up.
Use a new needle and make sure the flat side of the needle shaft is facing toward the back of the machine.
By hand, lower and then raise the needle as you hold onto the thread tail at the needle. This should pull the bobbin thread up through the needle plate. Take both threads under the presser foot and to the back of the machine.
Lower the presser foot onto the fabric and hold onto the thread tails or just hand walk the first stitch.
Feb 25, 2010 | Singer Sewing Machines
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
I have a Singer Touch and sew 600E and need to know how to thread the bobbin?
thread the machine up as normal, presser foot up,open the slide plate, push the button over to raise the winder, take the thread from the needle and wind it round a few times round the screw on the presser foot, press gently on the foot control and wind the bobbin, when you have enough thread close the slide plate and draw the threads to the back of the machine and away you go.
Jun 06, 2009 | Singer 3116 Simple
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
