Question about Sony Playstation 3 (PS3) Console
Ps3 systems update
Iam wireless belkin g plusmimo router sometimes down load 2% sometimes 35% then error80710723 HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 124 Answers
Just keep trying sometimes router cuts out on mine also sometimes takes 10tries try also resetting your router
Posted on Jan 07, 2009
Belkin share N300 # F7D3302, wireless router is slowing down page loading on my wired tower computer. Running windows XP pro. Had d-link prior and it worked ok, just since replacing it with Belkin, this...
There may be a web filter or monitoring option enabled on the router... check your running configuration to see if you have any of these filters or monitors enabled
Jul 21, 2011 | Belkin N Wireless Router wireless router
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Jan 04, 2011 | Belkin N1 Vision Wireless-N Wireless...
Need to change my nat setting from strict to open can't find anywhere on belkin wireless router settings
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
Jun 23, 2010 | Belkin Wireless-N Wireless Router with...
How do i connect ps3 to the internet using a belkin router
Hardwire your PS3 to router or connect it wirelessly by scanning from PS3....
Now hardwire your computer to any of the wired ports of the belkin router....
Goto start>run>type "cmd" >type "ipconfig" note down the default gateway address.....usually it ll be 192.168.2.1
now open any web browser and type the default gateway address in the address bar and hit enter.
In the belkin router set up page
Click FIREWALL and disable it....apply changes
click system setting and enable upnp....apply changes
click virtual servers and open the ports for PS3...and enable it...
that all...you are done with it...
you can also enable DMZ....it ll also resolves the issue....
Mar 03, 2010 | Belkin (F5D7231-4) Wireless Router
Is there anyway possible I can use my sprint wireless card on my ps3 by plugging it directly into the usb port on the ps3 for internet access?
No. Your PS3 does not the software loaded on it to run your wireless card. What you need is a 3g wireless router that is able to run your wireless card. Dlink makes a 3g wireless router.
http://www.dlink.com/products/?pid=524
Nov 02, 2009 | Belkin (F5D7230-4) Router (587009)
Ps3 will not conect wireless to my belkin n router
try this.. go to www.portforward.com.
scroll down and find the manufacturer and model # of your router.
on the next page look for PS3. This will show you how to configure the ports to allow access to your ps3. it is most likely being blocked by the routers firewall.
Sep 13, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin connection issue with 2 nd lap top
Hi iam router technician i understand your problem very well..To fix this issue all you have to do is,
First Confirm the model number its(starts with F5D & version (starts with VER) of your router and check for FIRMWARE update.
It may be quiet difficult for you to do up date firmware.please call toll free number"belkin" and ask them help you to update it..
..........Hope this information is help full for you ALL............
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Keep losing internet signal
Have you tried updating the firmware of your router? Updating the firmware of the router will fix that issue. Make sure after updating the router's firmware, hard reset the router. To hard reset it, Press the reset button on the back of the router for about 20 seconds, then unplug the power for 30 seconds then plug it back. Reconfigure the wireless settings of the router. Make sure to change the wireless channel of the router to channel 11 or 1 and not 6 to avoid interference.
Sep 16, 2008 | Belkin (F5D9230-4) Wireless Router...
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
