Question about D-Link DI 514 Wireless Router (DI-514)
Forgotten dl-624+ password and cant get into settings 192.168.0.1
Trying to set WII on WIFI using D-Link router but locked and forgotten the password tried to get on to settings but"http://192.168.0.1" just goes to google
  • 1 more comment
  • stuartbuckto Jan 05, 2009
    it gives me the same address but pressed re-set on back of router but now cant access net thruugh router
  • stuartbuckto Jan 06, 2009
    hi changed my browser from igoogle to blank in settings came on straight away
    many thanks for the fix
  • Anonymous Mar 29, 2014
    How do I set a password on my D-link, whenever I try to set some words as password the modem resets but hangs.
  • 104 Answers
If you’re using Windows, go to Start > (All) Programs >Accessories > Command Prompt.
You should see a command line window. Type in ipconfig and press return. In the output you see, the IP address under ‘Default Gateway’ should be your router address.
If this doesn’t work either, or it is showing the IP address you already tried, please come back to Fixya.
Posted on Jan 05, 2009
  • eecom Jan 05, 2009
    OK. I understand you decided to perform a reset.Loss of internet through router is normal after a reset.
    Can you login to your router now? If you can, there should be a setup wizard which will help you set up your internet connection again. If you need a manual or quick install instructions you can get them from the Dlink site.
    If you still can't login, please come back to Fixya - make a new posting if you have to.
  • eecom Jan 06, 2009
    Many thanks for the feedback!
How can I password my D-link router. Some is using my wireless API address
Enter the router configuration (192.168.1.1), user: admin, password: , and you must change on the Wifi configuration - you must set Security WPA2-PSK, under that you must set the password to connect on the wifi connection .
You must change password on the LAN / WAN from the Settings.
Apply all settings and restart router.
Please vote me is if you think my answer helped you.
Apr 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
The computer will not be able to pick up the D-link network I have set up if I switch the modem and router off. Even when I leave it running it will sometimes not get picked up.
try changing the encryption type. This sounds like the computer your using does not support the encryption type being used by the router.
1. Go to the setup screen of your router. For a D-Link router, you typically fireup your browser, go to http://192.168.1.1, and type in your username and password, my default username and password is admin, admin.
2. Click on the Wireless link. It will open Wireless settings.
3. There are options to let you set your Encryption Preferences. You can provide an encryption key that will be used by the router and any PC that wants to use the network.
4. select none. (if your wifi now works then you have found your problem and you can try the alternate encryption type, either WPA or WEP)
Mar 01, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I want to lock my wireless router, is DI 624 what i have to do?
You need to enable WEP security in router follow below procedure to secure your wireless network. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP security and enter WEP key it is your password to connect wifi.Then save settings and restart router . Then when anybody try to connect your wifi it ask for that password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 21, 2010 | D-Link Computers & Internet
I cant get my nintedno ds to connect to my router
The problem may be your security settings. The Wii and PSP can access WiFi no matter what the security settings are if you have the key, but the DS can't access highly encrypted WEP security. Double check your security settings and then re-input your code.
Jun 21, 2010 | Nintendo DS Lite Crimson & Black Console
Trying to reconnect my router but forgotten my password. Router has now locked-out. How do I re-set?
There is a small reset button on the back of the router. Hold it in for 10 seconds and release. Then you can setup the router from scratch.
Do you have your manual? If not, here is the link. http://cache-www.belkin.com/support/dl/f5d8632-4_usermanual.pdf
Jun 05, 2010 | Belkin N1 Vision Modem Router -...
Dl 624 wireless not authenticating
Try to MAC Cloning first. Open the router's admin page and look for MAC Address Clone setting. Enable it and save. You must power cycle the router and the modem after that.
Jun 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I forgot my username and password and want to create a VPN or remote connection
If you've forgotten the username and password, there is really no viable solution other than resetting the router. All the software can be found on linksys' website, along with manuals for reconfiguring your router. Breakout your trusty paperclip and press the reset button on the back of the router. Reconfiguring should only take a few minutes. The default username will be "admin" and the default password is "password" (both without the quotes.)
Manual
No software is actually required to install the router. Any information needed will be in the manaul, provided above.
Hope this helps!
May 29, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Using the DI-624 as a bridge
I don't think it can. An inexpensive wireless access point will work as a bridge. I use the TP Link brand with detachable antenna.
http://www.tplink.com/products/product_des.asp?id=116
Using the terms using the dlink router as bridge you get results of people who claim it can't be done because of firmware. The same question on the D-Link help site mentions DL to DL bridges, but not with the 624.
Carl
Jan 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-LINK ROUTER PASSWORD
hello... I have one problem,,I forget to password my router air plus G+. so, I want to reset my router,,how?
Oct 28, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need help with connect a d-link,dl 624 router
You wireless router/access point can host several simultaneous connections to the internet. Just connect your laptop to the wireless network as you would from your desktop computer.
Hope this helped.
MO
Jul 11, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
1,348 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
