Question about LG Refrigerators
Water dripping from the top of my fridge - LG Refrigerators
    Top Expert:
  • LG Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 08, 2012
  • sravas_ch Nov 10, 2012
    It's LG Intellocool model numberGL-195
  • 150 Answers
SOURCE: Kitchenaide fridge
your defrost condensate drain is clogged. kind of elaborate to explain can chat you through the fix
Posted on May 10, 2008
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, What brand/model# is this unit? I can help
Posted on May 23, 2009
Maytag317
  • 1136 Answers
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
SOURCE: Model GE TBX16SPCL Water dripping from
Michael, I live in an apartment that has this model. I had a similar problem that the apartment maintenance man concluded was a clogged vent. I don't no precisely what he did to fix it but it involved opening the vent compartment and cleaning it out. Be sure to take everything off the shelves of the refrigerator before your start because it makes a mess. Good luck.
Posted on Jul 05, 2009
Got water dripping into fridge from "vent" from
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Water dripping into the fridge and freezing
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 18, 2010 | Kenmore 74262 / 74264 / 74269 Top Freezer...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
General Electric Fridge/Freezer, dripping water in fridge
Refrigerator/freezers often have a de-icing cycle. Moisture condenses on the evaporator coils and freezes. The deice cycle melts and the water is supposed to flow through a tube to either a pan at the bottom of the fridge or a cup attached to the top of the compressor. Sounds to me there may be a plug or obstruction causing the water to back up. Test with water to see flow through the tube.
Another possibility is the seals around the doors and the insulation in the walls could be compromised. The seals are replaceable. Accessing the insulation is a major pain. I recommend finding another fridge to avoid such pain.
Oct 12, 2017 | GE Refrigerators
Having a water dripping from top of fridge!! p
The problem could be a number of things but you have to know the top of the fridge is the bottom of the freezer (usually) and this surface must be colder than the air that's being circulated in the refg compartment. Obviously Side by Side or bottom freezer would be differant.
4 items to check :
1your air damper switch is set to give you a colder freezer and not allowing enough cooling and dehumidification in the fridge compartment (explanation below of the reason you have to have air flow unobstructed)
2 the defrost on the freezer is not taking place (Explained below)
3 the door seals are not sealing. Use a piece of paper like a $1.00 and slide between the door gasket and the frame if you can pull and push it and it not fold up the seal is open and not working.
4 some fridges have a energy saver switch which is a heater. This switch turns the heater off. It is not needed in everyone's home or locality so the switch may be set to "save energy" and thus not keeping the "dew" off the fridge (usually these heaters are only on the doors and possible on the outer sides of the fridge and not the ceiling, so I doubt this is it, but I do like to eliminate this).
One of the more common things is the defrost not taking place and this can be a verity of thing Ive seen drain lines stop up and refreeze eventually to the point where the upper part of the fridge is too cold not to drip when the humidity come up like in the spring time. A faulty defrost timer / initiator or a bad element or safety switch, bad wire can also cause non defrost.
Defrost is required because the freezer is where the coldest part of the refrigeration circuit is and it requires air from the fridge to move over the coil. When this movement stops a cold ceiling can result. It will eventually follow with warmer fridge temps as humidity and time progresses.
Hope this helps with the mystery of most common problems associated with:
having a water dripping from top of fridge!!
Please grade ma accordingly and GOOD luck!.
Mar 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Jan 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
