Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Reassembly help First of all there is NO model number anywhere to be found on my Kenmore 27' Stack Washer Dryer. I was lucky enough to find the part number on the Transmission that allowed me to order a replacement. That number has been replace with 134735700 H Transmission and it does appear to be the same unit in every visual way. The Problem is that I took this apart two weeks ago and have now forgotten the order of reassembly. I very much need a diagram to assist me with the reassembly. All seals and spacer appear to be in very good condition. I just need a diagram 269-373-2970 Mark Wildig
The model # my be on the dryer door
Posted on Mar 28, 2008
  • 883 Answers
Try kenmore website for 800 customer service number
Posted on May 23, 2007
Kenmore stack top loading washer and dryer
kenmore washer won spin YouTube
Kenmore is sold by sears so go to
http://www.searspartsdirect.com/
Enter your model number to get user manual, parts diagrams parts lists and order parts.
Model numbers are usually covered by the lid or door.
Oct 01, 2014 | Washing Machines
I have a kenmore stacked washer/dryer. It's a top
With the sympthoms your describing its sounds to me as if the timer is going to be the problem. IT could be a lid switch problem but since it does drain i can pretty much eliminate the lid switch,or even the motor and narrow it down to the timer.
Reply with the entire stack unit model number as found on a label inside of the DRYER door and i will give ya the part number for the washer timer.
GENE
Sep 17, 2011 | Kenmore Washing Machines
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
I have a Kenmore stack washer/dryer. There is
you have to go in through the front and a total of 5 screws
Aug 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Want to stack my Kenmore HE4 Dryer on top of my Kenmore HE3t W/M
When you originally ordered the dryer, it should've come with a stacking kit that is compatible with the HE 3T or HE 4T washer. It is basically a foam piece that goes on each side of the washer, and then the dryer is connected to it from the side. If you do not have this piece, it should be available to order if you visit http://www.searspartsdirect.com Just enter the model number from your dryer (inside the door frame) and it should pull up a parts list. Or just try searching for a stacking kit for Kenmore dryer. Hope this helps.
May 18, 2009 | Kenmore Elite HE4 Electric Dryer
Washer and dryer
go to sears and get the stack kit the directions are in the kit
Apr 25, 2008 | Washing Machines
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
110 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
