Savin C2820 Color Copies and Prints Color Shifted Creating Blur
Savin C2820 Color Copies and Prints (from computer) have a shift in the colors (i.e. red and blue lines/text are separating and shifting) creating a shadow or blurred image of the original line/text. Yellow color is also being added as a margin. Any ideas about causes or solutions? Thanks.
4 Suggested Answers
ronaldsuboc
  • 449 Answers
SOURCE: Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Posted on Oct 31, 2008
  • 88 Answers
SOURCE: printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Posted on Mar 20, 2009
  • 217 Answers
SOURCE: hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Posted on Apr 05, 2010
Savin c9025/ ricoh mp2550 prints dull after changing toner
Download the software associated with the printer from the manufacturer web site to make sure you have the latest version. If this doesn't fix the problem you may have to buy a new print head for the printer. Also try taking the cartridge out and shaking it vigorously.
Feb 11, 2014 | Office Equipment & Supplies
Hopw to get meter count
Total prints B/w with FAX and total b/w copies equals total B/w color is prints and copies color scans? utility/counter button and do you want a print out?
Feb 21, 2013 | Konica Minolta Drum Cartridge for Bizhub...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
Savin C2824 Toner roller marks on blank side of color copies
dust from cartridge builds up inside machine. you can clean it up with a small paint brush and some canned air .
Jun 27, 2012 | Savin Office Equipment & Supplies
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Color problems with Hitachi Ultravision 53UDX10BA rear projection television
Blue color has shifted. two months ago it had shifted slightly. Now it has shifted more. All three bulbs are working. Please suggest a solution.
Jul 08, 2008 | Televison & Video
My HP PSC 950 printer copies and scans in color but prints in black
normally when the color tank runs out 2 things happen.
1] not all the colors run out at the same time.
2] the printer complains the tank needs to ne replaced.
If the tank isn't dry, it could simply be clogged. I like to use rubbing alcohol or distilled water and a cotton swab.
Dip the swab, & then gently apply pressure in the nozzles.
I would expect to see the clog before the cleaning process, some color to come off & when pressed on a paper towel, hopefully 3 bands.
Jul 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Copy Problem
this could be two things first, the transfer belt is slipping. It can be cleaned on the inside of the belt and the rubber drive roller. second, the laser units need to be timed, its not hard to do but a service tech will need to do both. it should be running great. the 3200 is a great box
Dec 06, 2007 | Canon imageRUNNER C3200 Color Printer
I have an HP 4600dn that is having trouble printing color.
there is a setting in the menu to adjust
go to Configuration
adjust color
you have to determine which way to adjust it on a X and Y axis
try changing the number X to a high # to see which way it moves then adjust from there.
Nov 21, 2007 | HP LaserJet 4600dn Color Printer
48 people viewed this question
jasbo
jasbo
