Question about Canon P160-dh Scientific Calculator
How to set calendar and clock on canon p160-dh
SOURCE: How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Posted on Nov 17, 2006
SOURCE: Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Posted on Mar 11, 2007
The trick is to hold down the time set button (=) until the time flashes and once the new info is entered, press time set and it will stay.  same with the date.  You kinda need to play around with it.  Thats how i learned.
Posted on Oct 07, 2008
  • 3 Answers
SOURCE: Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Posted on Jan 13, 2009
  • 102366 Answers
SOURCE: HOW DO I SET THE CLOCK ON THE P170-DH CANON
Refer to the first page on the instruction manual available on the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Posted on Mar 22, 2010
How do I reset the time and calandar?
press the calendar/clock key (top row, second from the left)
press the "=" key (clock/date set) and hold till display flashes
key in the correct date
key in the correct time and remember to select AM or PM (#/diamond key)
CE/E returns to calculator function
Oct 11, 2012 | Canon P170-DH Calculator
Setting time and date
The clock and calendar setting instructions are at the beginning of the manual.
Jul 19, 2012 | Canon P170-DH Calculator
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
Can't set the time on my Canon P170-DH adding machine
1. Press the calendar/clock button twice
2. Press and hold the Clock/Date Set (or Time Set) button for three seconds.
3. Use the numeric keys to enter the time -- four digits (i.e., 0730)
4. Press the AM/PM button to select
5. Press the Clock/Date Set (or Time Set) button
6. Press the C/CE button to return to calculation mode
Aug 27, 2009 | Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Can't set date
Download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Nov 15, 2008 | Canon P23-DH Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Calender
First Remove the clear tape from the battery compartment on the bottom. Second take a paper clip and press and hold the reset button for 5 seconds. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the date and press time set (M+/=) until it stops flashing. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the time and press time set (M+/=) until it stops flashing.
Apr 28, 2008 | Canon P23-DH Calculator
Canon P100-DH Calculator manual
How to change the roller ribbon on my Canon P100-dh calculator?
Jan 10, 2008 | Canon P100-DHII Calculator
Canon P160-dh Scientific Calculator Logo
94 people viewed this question
old marine
old marine
